It is currently Tue Oct 13, 2026 11:43 am
 Post subject: Using Border Average For Text
PostPosted: Sat Jan 26, 2013 4:26 am  (#1)
Esper, your a text guy, now that your here and this is a text subject so here goes.
Have you tried using, Colors menu > Info > Border Average... on an image you wish to add text on top of? If not give it a go!
Check your foreground color when you do.
 Post subject: Re: frost crystals text effect
PostPosted: Sat Jan 26, 2013 4:42 am  (#2)
Have you tried using, Colors menu, Info, Border Average... on an image you wish to add text on top of? If not give it a go!
i dont understand what you are saying
EDIT: wait, now i do,
will check
EDIT 2: im not quite sure what you want here from me
i used the script made a text, and then used Border Average, it seems to do nothing.....ir at least i cant see any difference :bluesad
PostPosted: Sat Jan 26, 2013 5:24 am  (#3)
Sorry my bad! It was not related to this thread.
You would use Border Average if you open any normal image and wished to overlay it with text. Border Average take an image color average and automatically adds it to the foreground color. This makes it much easier to find compatible text colors for an image.
PostPosted: Sat Jan 26, 2013 5:31 am  (#4)
ah, thats good, thanks Odin !
PostPosted: Sat Jan 26, 2013 5:57 am  (#5)
Where do you find this border average you are talking about Odin? :oops:
PostPosted: Sat Jan 26, 2013 6:04 am  (#6)
PostPosted: Sat Jan 26, 2013 6:10 am  (#7)
Thank you Esper. I wasn't looking under colors. I still don't know what you do with it cuz I tried it and nothing happens.
 Post subject: Re: Using Border Average For Text
PostPosted: Sat Jan 26, 2013 6:33 am  (#8)
Colours -> Info -> Border Average
molly asked:
so you take a colorful picture and run Border Average on it
what you will get is the average color as the foreground color
PostPosted: Sat Jan 26, 2013 6:39 am  (#9)
I tried it again and it did change my foreground color but I didn't get that average color box that you show.
PostPosted: Sat Jan 26, 2013 6:42 am  (#10)
thats just something i added for demonstration purposes
i used a gradient on the canvas, no black borders either
sorry if that was making things unclear
PostPosted: Sat Jan 26, 2013 6:49 am  (#11)
Thanks Esper, this will come in handy
Anyway it is just one of the Trillian things I haven't discovered yet on this Huge App.
PostPosted: Sat Jan 26, 2013 10:25 am  (#12)
:bigthup Thx guys!
bbbbbbbbbbbImage
PostPosted: Sat Jan 26, 2013 4:07 pm  (#13)
That is really cool info! I can't believe how many things there are that I have never known about in Gimp!
PostPosted: Sat Jan 26, 2013 9:02 pm  (#14)
aah, this is actually very helpful! thanks, odinbc, for bringing it up.
PostPosted: Sun Jan 27, 2013 12:50 am  (#15)
If you have an image that has border areas of similar color, make a selection of the area with the most color concentration before you run Border Average.
PostPosted: Sun Jan 27, 2013 2:40 am  (#16)
Good find Odin I think I'll add it to my outline script tomorrow
PostPosted: Sun Jan 27, 2013 4:51 am  (#17)
You are one busy little Script Bee Graechan,...keep em coming
PostPosted: Mon Jan 28, 2013 11:45 am  (#18)
I've tried it on a few photos, and I always seem to get an almost black or a light grey. I never get anything very colorful.
PostPosted: Mon Jan 28, 2013 11:48 am  (#19)
Try what Oden mentioned. Make a selection of a part of you image that you would like your foreground to be and run the script on that selection
