It is currently Sat Oct 17, 2026 3:34 pm
 Post subject: Creating 3D geometric shapes.
PostPosted: Fri Feb 01, 2013 11:19 am  (#1)
I need to create 3D geometric shapes (tetrahedrons, octahedrons, etc.) for a business logo design. I tried it 'freehand' but they aren't looking right. Any suggestions as to how to do this? Thanks.
 Post subject: Re: Creating 3D geometric shapes.
PostPosted: Fri Feb 01, 2013 11:39 am  (#2)
Maybe Inkscape is the right tool here? Esp for logo designs.
PostPosted: Fri Feb 01, 2013 12:11 pm  (#3)
Here is a link to a thread I started on here where I shared the five platonic shapes I had made, at the bottom of the first post you'll find the xcf files for each shape.
After some internet searching I found the easiest way of making them was to use the a golden ratio rectangle.
Hope this helps.
PostPosted: Fri Feb 01, 2013 12:21 pm  (#4)
Thanks, both will be helpful.
PostPosted: Fri Feb 01, 2013 12:40 pm  (#5)
You're welcome!
@he4rty! Very interesting, he4rty. I need to take a closer look at that thread.
3D Polyhedron extension is more versatile that i previously thought, have played around a bit to find out what it can do
PostPosted: Fri Feb 01, 2013 12:42 pm  (#6)
K1TesseraEna - Really cool, I'm going to have to get into inkscape I think.
