It is currently Sat Oct 17, 2026 10:14 am
 Post subject: Re: support thread
PostPosted: Sat Mar 02, 2013 11:30 am  (#1)
ok first grab 7zip from http://www.7zip.org
then you may open the stroke tutorial and the perfection.rar
as for the last that is the source code of a plugin , i believe that you need instead the Windows version
PostPosted: Mon Mar 04, 2013 10:40 am  (#2)
Hi...
Just been reading this with great interest and thought I'd try it. :) Sadly, got problem. Can't seem to get rid of the straight line. When I try to open the :brush editor...the boxes seem to be 'dead' :( They won't respond to 'clicks.'
I've just looked and I don't seem to have a 'Paint along Path' :pap option/icon either. Any ideas please. thanks for all your helpful 'Tuts' BTW....
Thanks
RalphC
PostPosted: Mon Mar 04, 2013 9:48 pm  (#3)
It takes me a long time, ( a very long time) from doing a tutorial to doing the tutorial well without having to keep reading it to knowing how to use the effects in the tutorial on my own in other projects.
PostPosted: Fri Mar 08, 2013 5:00 pm  (#4)
When you use the crop tool, set it to the size of your original layer which shows at the top of your gimp and in the screenshot below. click crop tool > fixed > size
> 800x600.
PostPosted: Fri Mar 08, 2013 10:03 pm  (#5)
Try this,
Edit → Preferences → Folders → Fonts
Add the Folder path.
You may have to restart Gimp.
PostPosted: Wed Mar 13, 2013 1:10 pm  (#6)
pls do not disappear, Esper
without you this site feels orphaned.
PostPosted: Wed Mar 13, 2013 1:14 pm  (#7)
it sure wouldn't be the same site without esper!
PostPosted: Fri Mar 15, 2013 10:11 am  (#8)
oh you were talking about the forum
well you select the text with your mouse, so that its blue, and in full editor mode there is a menu for Font Colour
PostPosted: Fri Mar 15, 2013 12:57 pm  (#9)
Esper wrote:
what i do, is add little descriptions in the layerproperties
Esper, would you explain how you do this. I put what I can in the layer name, but as a practical matter, I have to keep it short. I really wish I could keep notes in Gimp too.
PostPosted: Fri Mar 15, 2013 3:57 pm  (#10)
well just put the notes into the layerproperties that would help YOU recreate what you have done on that layer, next time you open your xcf, thats all
so if i made a dropshadow i might note down blur and offset values
PostPosted: Fri Mar 15, 2013 5:40 pm  (#11)
Thanks, I think I see now. When you said "layerproperties", my mind was translating that to "layer attributes", but you are using the comment field in "image properties" (alt - Return)... is this correct?
That is a good idea. I knew the image properties existed, but I never gave it much thought. Thanks for a good tip, and please correct me if there is a way to attach comments to individual layers.
PostPosted: Sat Mar 16, 2013 9:17 pm  (#12)
heh, I am also hoping to see that Ombre Tutorial.
PostPosted: Sat Mar 16, 2013 11:09 pm  (#13)
I'll add my vote to the last two, in hopes of an Ombre tutorial.
PostPosted: Tue Apr 09, 2013 8:19 pm  (#14)
Here are some rivets...
