It is currently Thu Aug 20, 2026 1:14 am
 Post subject: The Offset Menu
PostPosted: Sat Mar 02, 2013 9:31 pm  (#1)
when you use the Offset Menu in Gimp you have to put in values for the x-axis and the y-axis
Layer → Transform → Offset
i learned in school, that in a coordinate system, the x-axis is horizontical and the y-axis vertical
positive and negative values are like this
but in Gimp, the negative y-axis is on top - so the other way round
this is confusing me
is this a bug ??
 Post subject: Re: The Offset Menu
PostPosted: Sat Mar 02, 2013 10:11 pm  (#2)
It's not a bug. It was decided once by the dev's that the positive values move the layer to the right and downward.
Guess, western right to left style of writing had prevailed.
http://docs.gimp.org/2.8/en/gimp-layer-offset.html
Edit. *left to right, of course
PostPosted: Sat Mar 02, 2013 10:13 pm  (#3)
how odd
thanks K1te
PostPosted: Sat Mar 02, 2013 10:26 pm  (#4)
Esper wrote:
how odd
thanks K1te
No problem, Esper.
Maybe it has more to do with clockwise (more intuitive) movement rather than the writing style. Me guessing here, lol
BTW, did you know that you can offset layer masks as well, not just the layers?
I wrote a tutorial on that, but never published it here. Made an interesting animation based on layer masks offset.
PostPosted: Sat Mar 02, 2013 10:33 pm  (#5)
it doesnt surprise me as you can offset saved channels too
what would be the use of offsetting a layermask ?
PostPosted: Sat Mar 02, 2013 10:38 pm  (#6)
Esper wrote:
what would be the use off offsetting a layermask ?
hmm..... an animation...
Like this one
PostPosted: Sun Mar 03, 2013 1:39 am  (#7)
The logic is based upon the coordinates of the upper left corner of the image being x=0,y=0.
PostPosted: Sun Mar 03, 2013 2:05 am  (#8)
i see !
well thats a good way to memorize it too
PostPosted: Sun Mar 03, 2013 4:34 am  (#9)
Like this one
Wow! there is a big green worm going across my screen first thing I saw before I finished my first coffee.
That is cool Kit...as long as it stays inside the monitor. :jumpclap
PostPosted: Sun Mar 03, 2013 8:50 am  (#10)
Which itself stems from the coordinates system used in the various graphics APIs, which in turn use downward rows to be coherent with the top->down scan in CRT displays...
PostPosted: Sun Mar 03, 2013 11:14 pm  (#11)
Must be honest never found the offset that confusing as the minus movement is taking away from my pixel position so it just feels natural for the layer to then be moved up.
PostPosted: Mon Mar 04, 2013 5:52 am  (#12)
That's cleared it up for me too. Thanks for asking this Esper.
Lovely worm Kite. The animation is incredibly smooth. I'm always impressed with what you do.
