It is currently Sat Oct 10, 2026 6:45 pm
 Post subject: Why is file saved as .xcf when I chose .png?
PostPosted: Thu Nov 04, 2010 5:24 pm  (#1)
I chose .png and hit save and then I see that the file is saved as a .xcf.
I want .png since I read that .png is the best all round lossless format. I also read that .xcf is indeed lossy.
Whats the facts here?
 Post subject: Re: Why is file saved as .xcf when I chose .png?
PostPosted: Thu Nov 04, 2010 6:03 pm  (#2)
In GIMP, I've discovered that just selecting the filetype isn't enough, you have to manually type in the file extension as well. I've always considered that a bug, but no one else seems to have an opinion on it.
PostPosted: Thu Nov 04, 2010 6:33 pm  (#3)
XCF files are not lossy files at all. They keep ALL the data. I save everything as XCF files first and then save a copy as png, jpg, gif or whatever I need.
My Sigs = My Photos
PostPosted: Thu Nov 04, 2010 7:07 pm  (#4)
Yes as PhotoMaster said, save it as xcf first, that is the default for GIMP. It saves all your layers. If you want to go back and make changes to the layers, you can do that when it is xcf. Once they are changed to png, gif, jpg etc. you can't go back and change anything.
PostPosted: Sat Nov 06, 2010 9:47 am  (#5)
There is a plug-in that will save (export), a xcf gimp native fle along with a png on 1 click.
File/Export xcf and png
i have it but have no idea where i got it from...lol
ill try and find the script in my scripts folder and upload it here. =)
a list at the repository.
http://registry.gimp.org/search/node/sa ... d%20export
File comment: i think this is it =)
save_and_export_1.2.scm [5.04 KiB]
Downloaded 167 times
attach scm
