It is currently Wed Oct 14, 2026 11:47 am
 Post subject: View your XCF files with 'Sagethumbs' and then some...
PostPosted: Sat Apr 06, 2013 11:35 pm  (#1)
I've been using Gimp for nearly 10 years now. I never really gave much thought about being able to view my xcf files as thumbnails in windows, but it's possible with 'Sagethumbs'...
You can even view thumbnails of Gimp .gbr files with it.
http://code.google.com/p/sagethumbs/
 Post subject: Re: Sagethumbs, A Windows Explorer extension
PostPosted: Sun Apr 07, 2013 12:04 am  (#2)
It is indeed a very handy program.
Thanks Wallace.
PostPosted: Sun Apr 07, 2013 12:13 am  (#3)
Thanks Wallace.
@Rod,
Yes, it's most handy to have and it fits nicely into Windows right-click menu as well. ;)
 Post subject: Re: View your XCF files with 'Sagethumbs' and then some...
PostPosted: Sun Apr 07, 2013 2:32 am  (#4)
wallace: very good tool, i just tried it and will definitely keep it. thanks for the tip.
PostPosted: Sun Apr 07, 2013 4:15 am  (#5)
I've been using XnShell by XnView. SageThumbs and XnShell are based on the same code, is there any difference between the two?
PostPosted: Sun Apr 07, 2013 4:29 am  (#6)
Good prog, been using it for awhile now viewtopic.php?f=4&t=6013&p=75220&hilit=sagethumb#p75220
PostPosted: Sun Apr 07, 2013 10:50 am  (#7)
@Odin,
That's a good question, but unfortunately I don't have a clue.
PostPosted: Sun Apr 07, 2013 10:53 am  (#8)
K1TesseraEna wrote:
Good prog, been using it for awhile now http://gimpchat.com/viewtopic.php?f=4&t ... umb#p75220
@K1TesseraEna,
Ah, I see.
Thanks for providing the link. I agree and it's a really handy program for Gimpers or anyone else for that matter.
PostPosted: Sun Apr 07, 2013 10:58 am  (#9)
@AnMal,
No problem...
This topic has been mentioned before here on GC. Although I didn't see it, It's worth another mention nonetheless. ;)
