It is currently Mon Oct 12, 2026 2:15 am
 Post subject: can you scale from center ?
PostPosted: Tue Apr 16, 2013 3:05 am  (#1)
it seems the scaled object is pulled along the direction of the cursor....
is it possible to scale an object, so that it expands/shrinks from centre ?
also why is always the whole canvas selected when i scale a path ?
 Post subject: Re: can you scale from center ?
PostPosted: Tue Apr 16, 2013 5:15 am  (#2)
It is not possible.
To make your task easier, make a selection of your object (alpha to selection) and then scale it.
Grab scale grid by pivot point in the center and adjust/move. With enabled preview it should not be a problem.
The same here. Path to selection, scale tool -> the grid will be displayed just around your selection, not the whole canvas.
After scaling only the path will be scaled.
Edit. For the object choose 'Layer' in Scale Tool options, for the path - 'path', of course.
I know you know it Esper, just added for others unaware who may read this
PostPosted: Tue Apr 16, 2013 7:02 am  (#3)
You can float the selection and then use "Layer->Scale Layer..."; however, this will not provide interactive feedback.
Paths themselves are merely mathematical formulas, and those formulas are based upon image(/canvas) coordinates. Scaling (of paths) likewise needs to be based upon image coordinates.
PostPosted: Tue Apr 16, 2013 8:24 am  (#4)
My pet explanation is that paths, like channels, are associated to the canvas and not to a specific layer....
PostPosted: Tue Apr 16, 2013 5:47 pm  (#5)
Thanks K1te, saulgoode, and ofnuts for the answers !
PostPosted: Mon Sep 02, 2013 6:51 pm  (#6)
Just wanted to say thanks as well about the paths. I've done this by accident before by having my selection hidden and thought I was just forgetting a setting. Oddly enough, I could never recreate it consitantly. =P
The explanation for this behaviour made it all click!
Thank You :tyspin
Gimp 2.8.16
Arch Linux - XFCE 4.12
Some of my work.
PostPosted: Tue Sep 03, 2013 11:57 am  (#7)
Just as a word of warning, when I use alpha to select and then scale the image down a ghost of the image in the original size is left behind. This isn't always obvious as it depends on the complexity of the image scaled and the background that it's on. An easy way to see if this is effecting any other Gimp install is to start with a white canvas, add a new layer, on the new layer use the path tool to make a jagged line, stroke the path, alpha to select on the path layer then scale down using shift T. A ghost image of the original line should be left. It will be interesting to know if others have this problem.
DeviantArt gallery
PostPosted: Tue Sep 03, 2013 12:23 pm  (#8)
Caz, that's only happening when you stroke the path with Antialiasing selected.
You don't need this option to stroke polygonal (rectangular) paths, and to stroke curved paths... well, scale up/down the path
then stroke [with Antialiasing]. :)
PostPosted: Tue Sep 03, 2013 12:53 pm  (#9)
If you want to select the whole image w/o the canvas being messed up select all and do it.
Control + a is the quick way to select everything.
PostPosted: Tue Sep 03, 2013 1:05 pm  (#10)
Thank you very much. This one's been bugging me for ages, I even had to resort to using the eraser to remove the ghost image. Not any more though :yes
DeviantArt gallery
PostPosted: Tue Sep 03, 2013 1:12 pm  (#11)
I think the main point of the OP was about inconvenience and less accuracy of selecting the whole canvas
when you need to scale down/up just the small objects and paths.
