It is currently Sun Oct 18, 2026 1:32 pm
 Post subject: need a distortion filter suggestion
PostPosted: Sat Apr 27, 2013 2:56 pm  (#1)
is there a filter that lets me get that ripple effect you can see on the wires ?
i made this text from different bands of colour and now i want to distort it so that i looks like the wirespools
but 'Wind' only works on edges and all the other filters, including G'MIC dont seem do to the job either
got this result with a combination of Spread Noise and Ripple
 Post subject: Re: need a distortion filter suggestion
PostPosted: Sat Apr 27, 2013 3:18 pm  (#2)
new image
filled with gradient
use of Filter>Distorts>Shift
could be used?
PostPosted: Sat Apr 27, 2013 7:58 pm  (#3)
thanks dinasset for the suggestion, i think Shift is looking too regular and only to one side
PostPosted: Sat Apr 27, 2013 9:22 pm  (#4)
Here are two links to spools of copper wire, Esper. Do they have the effect you are looking for?
http://images.wisegeek.com/copper-wire.jpg
http://ttc2010.files.wordpress.com/2010/06/8249831.jpg
PostPosted: Sat Apr 27, 2013 10:07 pm  (#5)
Is this something what you're after, Esper?
Image Image
Edit. I don't have copper gradient, so I applied a distortion on BW Crown Moulder gradient and colored it to look like copper.
Displacing gradient by 20 or so along X axis.
To make a displacement map - add correlated RGB noise at 60% to the white bg and wind-distort at about 30 for Strength. I used 'Both' for Edge
in this example but don't think it really matters.
PostPosted: Sat Apr 27, 2013 10:55 pm  (#6)
You could do RGB noise (on a grey layer), Motion Blur, De-saturate, Unsharp Mask and Darken with Curves to achieve a wire spool look.
Alan
PostPosted: Sun Apr 28, 2013 12:13 am  (#7)
Did have a quick play and I think the problem I'm seeing is the fact the text is flat but the spools are curved and the light/shadows created by the curve is hard to translate to the text.
PostPosted: Sun Apr 28, 2013 7:00 am  (#8)
[ Image ] [ Image ]
This is excellent! :bigthup
PostPosted: Sun Apr 28, 2013 9:10 am  (#9)
K1te, you are a hero !!!! :clap
your result is pretty much was i was after, even the colours !
thank you !!
@Oregonian: thanks for your help, i wasnt really asking for copperspools, but after i read your comment in Rod's Steampunk-Copper-Effect, i had to give copper a go ;)
btw, this is what i got in the first round
its far from good and looks more like a cookie :mrgreen:
thanks, sounds pretty complicated, i will have to gove it a try
tbh, im not really going for a spool look, but just this basic zigzag/ripple effect
i agree and it will not work with my coloured try either, despite the fact that K1te came up with a great idea for the look i was asking for
but this will be useful for other metal-texture-effect
and this is what im really after
PostPosted: Sun Apr 28, 2013 9:47 am  (#10)
here is Kite's spool with the copper gradient supplied in Rod's Steampunk post.
I applied the map to gradient , a small curve correction to go more reddish and a gaussian blur Horizontal 4 vertical 0. Image
PostPosted: Sun Apr 28, 2013 9:52 am  (#11)
I actually grabbed your image and used Change Image on it to obtain the gradient.
Results
And with a little brightness and contrast manipulation.
copper-pipes_RD.ggr [1.06 KiB]
Downloaded 817 times
PostPosted: Sun Apr 28, 2013 11:44 am  (#12)
There is a filter 'Deformation / Ripple' in G'MIC that looks exactly the same, when parameters are finely tuned :)
File comment: G'MIC Ripple filter
PostPosted: Sun Apr 28, 2013 11:50 am  (#13)
of course i tried that ! ;)
in fact it was my first choice, but it didnt give me the exact effect i was looking for
PostPosted: Sun Apr 28, 2013 7:18 pm  (#14)
lots of good things coming out of this thread ! :clap
i tried to apply the new techniques
PostPosted: Mon Apr 29, 2013 8:10 am  (#15)
Nice effect, Esper! Looks like brushed metal.
I'm gonna play around with this technique and see if i can make
various hq brushed metal textures for my 3D projects.
Edit. Just dawned on me - I can use these textures to imitate anisotropic
light scattering on distant objects where i don't need great amount of detail
instead of using expensive anisotropic shader in Blender! Cool!
@Rod Cool idea to use pixel spread!
Could be useful for my projects too.
PostPosted: Mon Apr 29, 2013 8:28 am  (#16)
Esper that looks terrific! It has a real metallic look to it :bigthup
Note: After using Noise>Spread i had to trim the edges a wee bit as they were roughed up.As you can see in the spread interface preview. :)
