It is currently Mon Nov 23, 2026 11:59 am
 Post subject: I give up
PostPosted: Sun Nov 14, 2010 5:07 pm  (#1)
As you can see in the picture below, I have gmic in gimp..but it will not show up under filters...so I give up.
My question is, does anyone know of a good brush I guess for doing polka dots and snowflakes?
Thank you to everyone that has worked with me on this.
Micki
 Post subject: Re: I give up
PostPosted: Sun Nov 14, 2010 5:25 pm  (#2)
Don't give up. Leave it there where it is. I wouldn't take it out again cuz some good techie will come along and maybe they can help you. Don't worry, we have all been there. I have the same problem with Phython. It shows everything there but I am unable to use any of the scripts... they come up blank....
PostPosted: Sun Nov 14, 2010 5:29 pm  (#3)
Folder desigination for your user looks wrong. it should be c:\Documents and Settings\Owner\.gimp-2.6\plug-ins and not with the _gmic subdirectory (using your paths). GIMP will find all the plugins in subdirectories. Your gmic plugin should be in plugins directory and there is an additional subdirectory _gmic as you have in your plugins directory. I think that is your problem. Edit the path as I mentioned, close GIMP and re-open it again and I bet it will work. Below are the files that should be in your user plugins directory. :)
PostPosted: Sun Nov 14, 2010 5:33 pm  (#4)
Not understanding what you mean? could you explain in a easy English...LOL and how I can edit it and do I edit at the doc and settings file or the file /preferences?
Micki
PostPosted: Sun Nov 14, 2010 5:36 pm  (#5)
Exactly change that user doc path to NOT include the g_mic folder...thats your problem.
It cant find G'MIC.exe
PostPosted: Sun Nov 14, 2010 6:05 pm  (#6)
OK Micki; just go to your plugin paths preset and click on your user path (I use Win7, so mine's different then yours). Then end of the path though is identical (\plug-ins part). See the screenshot below. :)
