It is currently Sat Oct 10, 2026 10:13 pm
 Post subject: how do you improve images like this ? [moire]
PostPosted: Mon Sep 02, 2013 5:11 pm  (#1)
is that pattern an artifact from a scanning process ?
http://25.media.tumblr.com/1899625d54de ... 2_1280.jpg
what technique could improve this image ?
 Post subject: Re: how do you improve images like this ?
PostPosted: Mon Sep 02, 2013 5:21 pm  (#2)
What a strange pattern has that image.
I guess with some despeckle and smooth techniques, GIMP Despeckle, G'MIC Remove Hot Pixels and G'MIC Smooth anisotropic.
But I do not think it's possible to remove that pattern totally only using filters.
I do not see interlace distortions in the image,so deinterlace I do not think is useful. This pattern seems to be because the canvas where the image has been printed.
Edit:
Only with filters. Remove Hot Pixel, GIMP Despeckle, Smooth Anisotropic, very little Sharpen deblur
PostPosted: Mon Sep 02, 2013 6:53 pm  (#3)
Hi Yafu, this filter (Remove Hot Pixel) has the G'mic?
That I do not know.v :puzzled
I did a highlighted in color, then used the filters Despekle and (G'MIC) Smooth thin brush.
I think for a good result, the clone tool would need
bbbbbbbbbbbImage
PostPosted: Mon Sep 02, 2013 7:16 pm  (#4)
@Akros, yes. Under Repair menu.
PostPosted: Tue Sep 03, 2013 9:52 am  (#5)
thanks Yafu and Akros
improving images is beyond my knowledge, you both clearly know your stuff
PostPosted: Tue Sep 03, 2013 10:05 am  (#6)
Just ran Ian's noise reduction on it. (Is in G'MIC)
Cool job guys. Mine looked a lot clearer before I uploaded it.
PostPosted: Tue Sep 03, 2013 3:56 pm  (#7)
Used G'MIC Fourier Transform to remove the frequency noise (regular pattern noise), then one step of G'MIC anisotropic smoothing.
PostPosted: Tue Sep 03, 2013 4:47 pm  (#8)
Good work on the photo, wouldn't know where to begin.
PostPosted: Tue Sep 03, 2013 4:54 pm  (#9)
thanks sallyanne !
the direct transform gave me a strange all grey image as output and the inverse transform an error
PostPosted: Tue Sep 03, 2013 5:25 pm  (#10)
Hi guys!
Where exactly is this filter (Fourier Transform) located?
bbbbbbbbbbbImage
PostPosted: Tue Sep 03, 2013 5:32 pm  (#11)
great job Ronounours
PostPosted: Tue Sep 03, 2013 5:37 pm  (#12)
G'MIC -> Spectral Filters -> Fourier Transform
PostPosted: Tue Sep 03, 2013 5:50 pm  (#13)
Thx Esper! :bigthup
But cant see the preview using that filter.
With option --> Transform Direct, the preview is transparent;
With the option Transform Inverse, No preview avaliable.
bbbbbbbbbbbImage
PostPosted: Tue Sep 03, 2013 5:58 pm  (#14)
same here
PostPosted: Tue Sep 03, 2013 6:02 pm  (#15)
The direct transform gave me a strange all grey image too, and changed the appearance of how layers are displayed in layers dialog.
bbbbbbbbbbbImage
PostPosted: Tue Sep 03, 2013 6:02 pm  (#16)
yep :mrgreen:
i guess Ronounours can solve that mystery
PostPosted: Wed Sep 04, 2013 2:37 am  (#17)
Happened to me too
PostPosted: Wed Sep 04, 2013 5:31 am  (#18)
I got some pretty good results by just using Repair>Smoothing - anisotropic with these settings.
Results-
PostPosted: Wed Sep 04, 2013 9:38 am  (#19)
To Esper,
Since no one said anything about the origin of the strange pattern:
It is not caused by scanning,on the contrary this is a good scanner.
The picture must have been from a glossy magazine or similar.
The machine that prints it uses this pattern to regulate the amount of printing ink.
Without it the colors would bleed.
Gerard.
Gimp-2.8.14
I use Linux only.
And Virtualbox with Win 7
PostPosted: Wed Sep 04, 2013 9:40 am  (#20)
Another quick way to get a reasonable image is gaussian blur 5, sharpen 60, duplicate the layer overlay mode 40 %, flatten and sharpen 60 , save as jpg
