It is currently Sat Oct 10, 2026 6:45 pm
 Post subject: Upgrade problem
PostPosted: Tue Oct 15, 2013 6:45 am  (#1)
Hello.
A year ago, I had huge problems when I tried to install Gimp 2.8 from Gimpusers.com and SourceForge (both English-speaking pages ) but Gimp installed with swedish language I do not ask for. I try to change the language to English at the Gimp preference but Gimp dont let me do that. After many attempts I tried to download Gimp from a different page and then it worked with Gimp English. I don't remember what page I downloaded it from. Do you know where to look.
Today I tried to upgrade to Gimp 2.8.6 but I land up with the same irritating problem as one year ago.
After downloading procedure Gimp lands up at my dock
But not in english. Why.
When I try to open up those pattern and fonts nothing happen. Why
Do you know where I can find an English -speaking Gimp for macusers.
I no longer see where to download Bling Bling script fu.
I run on a iMac mid 2011 10.8.5 64 bits
Thanks
Lurifax.
Late 2017 iMac Retina 4K 21,5 inch Mac OS High Sierra version 10.13.4
3,6 GHz Intel Core i7
16 GB Ram 2400 MHz DDR4
Graphic card Radeon Pro 560 4096 MB
Affinity Photo and Affinity Designers.
 Post subject: Re: Upgrade problem
PostPosted: Tue Oct 15, 2013 7:08 am  (#2)
This happened to me on this laptop (which used to be AnMal's) There is a file in Gimp's directories that has a list of languages on and we found out that the only way to switch to English was to delete all other languages from that file. I will have a look to find which file it is for you.
PostPosted: Tue Oct 15, 2013 8:16 am  (#3)
"En" , en is for English,
the language files should be in : share> locale
PostPosted: Tue Oct 15, 2013 8:41 am  (#4)
I use the mcgimp from Partha's site...partha's place. It is easy to install and works great! It is specifically made for osx and has the most popular plug-ins already in the file.
PostPosted: Tue Oct 15, 2013 9:38 am  (#5)
Thank you all for helping.
Erisian,
I appreciate your help. Thank you .
Photo Comix.
Yes it is true, but if you have downloaded the wrong version then there is no box to enter Ea
2-ton Exiting.
I downloaded Gimp 2.8.6 from Partha's Place
But I got this chrashmessages. May I need to try something els.
Lurifax.
PostPosted: Tue Oct 15, 2013 12:46 pm  (#6)
I solved all the problems myself and even to download and install the Script-Fu Enviro -Logo.
I still need help finding the script -fu for "Bling Bling" projects. Where are they scripts hiding.Tell me.
Thanks
Lurifax
PostPosted: Tue Oct 15, 2013 12:57 pm  (#7)
Good to know you've sorted it.
PostPosted: Tue Oct 15, 2013 4:32 pm  (#8)
Thank you:
PostPosted: Wed Oct 16, 2013 4:42 am  (#9)
Lurifax73 wrote:
Thank you:
:oops: :oops: :oops: I'm flattered! :)
PostPosted: Wed Oct 16, 2013 4:46 am  (#10)
What a peculiar problem to have.
PostPosted: Wed Oct 16, 2013 5:52 am  (#11)
Erisian,
Photo Comix.
2-ton Exiting.
Lurifax.
The crash shows that you are missing a basic library which is included with McGimp 2.8. Is it possible your download was corrupted by any chance? If you wish to solve this issues, please IM me or leave me a message on my website.
Thanks,
Partha
PostPosted: Wed Oct 16, 2013 6:42 am  (#12)
Thank you partha.
I have not worked with Gimp for about a year and therefore forgotten how to install the software. Now it looks like everything is working.
Your downloads seams to be more easy to manages than others.
Thanks for that.
Lurifax.
