It is currently Mon Oct 12, 2026 10:51 pm
 Post subject: layerfx bug in 2.8.8 ?
PostPosted: Mon Nov 25, 2013 7:00 am  (#1)
since i upgraded to 2.8.8. i noticed that layerfx behaves differently
when i start the python script for the Bevel & Emboss, the values for Depth, Size and Soften are blank
also i noticed that while the plug-in works, there is briefly a flash of a dialogue, i think it says something about Bump-Map Plug-in...
it wasnt like that before
it seems every layerfx plug-in that has a Size-value, has the same bug, they all appear blank until you change the value
note that i use the older layerfx.py, not layerfx2.8.py, because that one had the bug with the layergroups
http://registry.gimp.org/node/186
 Post subject: Re: layerfx bug in 2.8.8 ?
PostPosted: Mon Nov 25, 2013 4:08 pm  (#2)
confirmed on win 7 gimp 2.8.8.
i'm afraid layerfx.py will not work in 2.10 (more changes to API coming)
gimp is useless without layer effects! :gaah
but seriously, I've heard most of 3rd party C plugins will have to be ported to GEGL now,
otherwise they won't work
PostPosted: Mon Nov 25, 2013 4:28 pm  (#3)
lol, evil K1te
PostPosted: Mon Nov 25, 2013 5:23 pm  (#4)
Note! The Script-Fu version is not effected
PostPosted: Mon Nov 25, 2013 5:34 pm  (#5)
Woo hood thanks graechan
