It is currently Sat Oct 10, 2026 5:33 pm
 Post subject: Rough Cut
PostPosted: Wed Dec 04, 2013 11:30 pm  (#1)
Does this look like roughly cut metal
 Post subject: Re: Rough Cut
PostPosted: Wed Dec 04, 2013 11:36 pm  (#2)
I'm not sure, but it's really a good text effect. The only thing is that the 'cut' part doesn't look the same, or is different from the top text.
PostPosted: Thu Dec 05, 2013 8:37 am  (#3)
yes, it looks slightly metallic
it also looks like a metalized animal skin
but does it matter ?
it looks good :bigthup
personally i would like a mix between version one and two
version one is a bit too rough, while version two is a bit too smooth
all in all a very promising effect
hope you will improve it for a script, Graechan
i know everybody will love it
PostPosted: Thu Dec 05, 2013 8:45 am  (#4)
It certainly is an intriguing effect.
PostPosted: Thu Dec 05, 2013 9:17 am  (#5)
Looking forward to the end result. :)
