It is currently Sun Oct 11, 2026 2:21 pm
 Post subject: Plugins that do not work in 2.8.10
PostPosted: Fri Dec 13, 2013 8:57 pm  (#1)
this is a list of plugins that are failing in 2.8.10 there are undoubtedly more
CalendarGenerator
separate.exe
icc_colorspace.exe
 Post subject: Re: Plugins that do not work in 2.8.10
PostPosted: Fri Dec 13, 2013 9:02 pm  (#2)
Graechan wrote:
this is a list of plugins that are failing in 2.6.10 there are undoubtedly more
CalendarGenerator
separate.exe
icc_colorspace.exe
The topic says 2.8.10 & your post says 2.6.10? which version is it that is causing the failed plugins?
PostPosted: Fri Dec 13, 2013 9:06 pm  (#3)
good pickup Mackenzieh just wanted to see if everyone was still awake :bigthup :hehe
all fixed now
PostPosted: Sat Dec 14, 2013 12:06 am  (#4)
Well, none of those Window's Binary exe's ever worked in Linux (natively).
..I'm just saying. :hehe
PostPosted: Sat Dec 14, 2013 12:38 am  (#5)
I don't have any of those installed so i guess i am ok. :)
Probably need to be compiled with the GIMP 2.8.10 libraries Graechan.
Maybe Sam or Lyle can help. As far as i know they are the only two with working compile environments.
PostPosted: Sat Dec 14, 2013 9:11 am  (#6)
CalendarGenerator
separate.exe
icc_colorspace.exe
Don't know about CalendarGenerator
Separate+ plugin
For those who want to convert an image to CMYK and there are possibly better non-gimp ways.
I'm with GnuTux, no problems here in linux (PClinuxOS 32 bit KDE)
For M$ Windows Win7 VM and Gimp 2.8.10
Just a reminder that (certainly 32 bit, have not got round to 64 bit yet from memory I think it works) copying and renaming the offending .dll still works.
Copy (repeat copy) C:\Program Files\GIMP 2\bin\libtiff-5.dll to your Users /.gimp-2.8 plug-ins folder along with the separate plus files. Rename this copy to libtiff3.dll
screenshots http://i.imgur.com/LXUD9kr.jpg and http://i.imgur.com/sRBuB8W.jpg
That gets it working, it does export and import and you can change the icc profile.
screenshot: http://i.imgur.com/bFd3dKf.jpg
PostPosted: Sat Dec 14, 2013 10:03 am  (#7)
I have another one to add to your list.
GAP 2.6
. . . . doesn't appear to want to work in GIMP 2.8.10 Windows 64bit, on Windows 7 64bit. The plug-ins fail initialize when GIMP scans the plugins folder - each plug-in is unable to start.
Although I can still use it in GAP 2.6 in GIMP 2.8.2 64bit - just weird.
