It is currently Mon Aug 17, 2026 5:06 pm
 Post subject: Order in Gimp
PostPosted: Wed Mar 12, 2014 10:55 am  (#1)
Is it possible to cather all scripts, witch are for photo editing in their own folder an put the name up here? If it is, would some friendly soul tell me how, or where I can get instructions?
I really hope to get in Gimp some order in scripts and other things too.
 Post subject: Re: Order in Gimp
PostPosted: Wed Mar 12, 2014 11:11 am  (#2)
scripts and python can be put under the menu you like simply editing the source with notepad++, looking for the registration line and replace -for instance- Filters with PhotoFilters or whatever you like (submenus included).
Much more difficult to change the menu of the plug-ins in .exe.
You should have the source and be able to compile it after the changes (not an easy task, ask Rod for instance...)
PostPosted: Wed Mar 12, 2014 11:11 am  (#3)
@himppu All your scripts go into your user script folder and your plug-ins go to your user plug-in folder, The same with gradients, patterns etc.
They don't go at the top of your gimp the way you show it in your image.
If you have Windows, they go in C:\users/your name\.gimp-2.8.XX\scripts > C:\users/your name\.gimp-2.8.XX\plug-ins etc.
PostPosted: Wed Mar 12, 2014 11:56 am  (#4)
The GIMP documentation about script-fu page shows how a script registers itself into a menu:
http://docs.gimp.org/en/gimp-using-scri ... cript.html
So by changing the path shown in the script-fu-menu-register line you can alter where the script appears.
It is also possible to add extra script-fu-menu-register entries so you could leave the scripts as they are and create a new .scm file containing a series of script-fu-menu-register entries for each of the scripts you want to collect together.
This extra file would have to be loaded last for it to work - maybe put it into a new folder on it's own and make sure the new folder is last in the folder list in your preferences.
Kevin
Here's an example mylist.scm that I've put into a mylist folder:
(define kp24_mylist_menu "<Image>/mylist")
(script-fu-menu-register "script-fu-kp24_dragan" kp24_mylist_menu)
(script-fu-menu-register "script-fu-kp_grad_filter" kp24_mylist_menu)
(script-fu-menu-register "script-fu-kp24_make_printable" kp24_mylist_menu)
(script-fu-menu-register "script-fu-kp24_process_negs" kp24_mylist_menu)
PostPosted: Wed Mar 12, 2014 6:20 pm  (#5)
Scripts
You can Start by separating you scripts into folders inside your scripts folders then adding a new path for each of these folders in preferences (max 15), then using notepad++ or similiar editor, alter their registration path
Gimp Plugins
To alter the registration path for Gimp plugins open your pluginrc file in your editor and search for the plugin you wish to change then alter it's registration path
Photoshop Plugins
To alter the registration path for Photoshop plugins open your pspirc file in your editor and search for the plugin you wish to change then alter it's registration path
PostPosted: Fri Mar 14, 2014 8:13 am  (#6)
Thank you all! I'll make a backup and get to work. Will tell you how it went. I am a bit scared but also sturdy :)
PostPosted: Fri Mar 14, 2014 8:20 am  (#7)
thanks Graechan, for recalling the use of the rc files!
Only a little little additional note for the novices: if -for any good reason- you have to delete the rc files, remember to reapply the modifications...
