It is currently Wed Aug 19, 2026 5:54 am
 Post subject: Hello again (Or now me has a question)
PostPosted: Fri Aug 28, 2015 11:37 am  (#1)
Well, I cannot say that I am new, but it has been awhile.
Suddenly I seem to have more free time on my hands and I hope to be seeing more of gimpchat again.
Plus, I have lots of questions, hahaha.
Nixnine
QUESTION BELOW
 Post subject: Re: Hello again
PostPosted: Fri Aug 28, 2015 12:00 pm  (#2)
Welcome back nixnine. I love your sig!
PostPosted: Fri Aug 28, 2015 12:07 pm  (#3)
Good to have you back on deck nixnine.
PostPosted: Fri Aug 28, 2015 12:52 pm  (#4)
PostPosted: Fri Aug 28, 2015 2:28 pm  (#5)
WB Nixnine. That sig bears some pondering ...
Wallace, I love the Wilbur!
(Solve if you can ... ;) )
PostPosted: Fri Aug 28, 2015 2:54 pm  (#6)
Thanks Jazzon!
It was a simple idea. The font I used is named, "That's Font Folks".
thats_font_folks.zip [22.71 KiB]
Downloaded 102 times
If you're using Windows you can find that Wilber image at or near, share\gimp\2.0\images of your Gimp program files.
PostPosted: Fri Aug 28, 2015 6:47 pm  (#7)
Welcome back Nixnine, great to see you back.
PostPosted: Sat Aug 29, 2015 2:06 am  (#8)
Happy for your back Nixnine. :)
Wallace, nice outcome, I like it a lot. :hi5
PostPosted: Sat Aug 29, 2015 5:56 am  (#9)
Thanks Issa! :bigthup
PostPosted: Sat Aug 29, 2015 8:01 am  (#10)
Nice to see you back, Nixnine! :mrgreen:
PostPosted: Sat Aug 29, 2015 1:32 pm  (#11)
welcome to the forum
PostPosted: Sat Aug 29, 2015 3:46 pm  (#12)
Welcome to Gimp Chat nixnine
PostPosted: Sun Aug 30, 2015 7:58 am  (#13)
nixnine: welcome back! hope you get lots of gimping and gimp chatting time and can join in all the fun here.
PostPosted: Fri Sep 04, 2015 9:09 pm  (#14)
Thanks guys, good to be back.
Got a question. I remember a script that would take, say a sprite sheet, and split it into individual layers for each image on the sheet. I cannot for the life of me remember the name. I went through my scripts folder and was trying to figure it what it was, but with 400 + scripts I am not sure. Anyone remember this script's name?
PostPosted: Fri Sep 04, 2015 9:13 pm  (#15)
What is a "sprite sheet"?
PostPosted: Fri Sep 04, 2015 9:17 pm  (#16)
Here's an example. I have an layer with several images that I need to separate and I remember this script did it fairly well, i just can't remember the name of it.
 Post subject: Re: Hello again (Or now me has a question)
PostPosted: Fri Sep 04, 2015 10:03 pm  (#17)
There is G'MIC Montage.
I frequently use, CSS WebSprites: Arrange layers and create a CSS file
Quick and easy (for spacing first increase canvas size & center): Fuse layers
I think ofnuts has a script that does that and there is another that I can't remember I'll look for both.
ofnuts: arrange-layers
IGLO - Images Grid LayOut
PostPosted: Sat Sep 05, 2015 6:36 pm  (#18)
If someone can change a PS script into a Gimp script ...
https://photoshopscripts.wordpress.com/ ... to-layers/
PostPosted: Sat Sep 05, 2015 8:34 pm  (#19)
This is one strange sprite sheet.
All the ones i have seen usually are placed such that if you divide width by a constant x and divide height by a constant y you can extract the single images out.
With your sprite i can't even visuallize lines to divide them evenly.
apparently theses uneven sprite sheets exists...so how would you know how extract these images manually (in steps that could be converted to a script)?
TinT
PostPosted: Sat Sep 05, 2015 9:23 pm  (#20)
Don't know about a script but G'MIC has a filter called Extract Objects found under Arrays and Tiles
I just tried it...not done so before. Will extract the pictures onto different layers
It just squares them tran to make them all the same which I guess is what a script would do
I have attached the extracted picture so you can see what it does.
megaman7.xcf
