It is currently Mon Aug 17, 2026 3:05 pm
 Post subject: Newbie with simple question
PostPosted: Thu Dec 22, 2016 10:51 am  (#1)
Glad to join! I am new to GIMP and downloaded/extracted/installed the latest version on a Win10 desktop. IT did not create an icon to launch and I cannot find the executable file to do so.
What am I doing wrong? :gaah
 Post subject: Re: Newbie with simple question
PostPosted: Thu Dec 22, 2016 11:02 am  (#2)
Hi chuck
Welcome to Gimp Chat.
There isn't enough information to be able to give a good answer. You will need to provide some more info. You say that you downloaded the latest version. What version is that? Where did you download it from? Please give as detailed a reply as you can.
PostPosted: Thu Dec 22, 2016 11:08 am  (#3)
Nothing wrong really. Typical Windows click-n-wish
You should have used the 'customise' option see:
https://www.youtube.com/watch?v=klV_1PslFG4
Otherwise all you need to do is make a shortcut to
C:\Program Files\GIMP 2\bin\gimp-2.8.exe
PostPosted: Thu Dec 22, 2016 12:28 pm  (#4)
Thank you Rich! I found the exe file and created the desktop icon. I am up and learning!
PostPosted: Thu Dec 22, 2016 1:00 pm  (#5)
Welcome to Gimp Chat Chuck. :)
PostPosted: Fri Dec 23, 2016 5:24 am  (#6)
Welcome to Gimp Chat, Chuck. :)
PostPosted: Fri Dec 23, 2016 4:33 pm  (#7)
