Tikiman1972 wrote:
...snip...My problem is that I am unable to print 4" x 6" photographs that are borderless and I would like to enter a dialog with someone with the knowledge to help out...snip...
Since you are using linux, you could try the gutenprint plugin. It will be in the Mint repo for installation.
The Canon MG5550 is listed as supported, Several years since I swore off Canon, maybe their linux support has improved. I use a Brother inkjet now.
I am in the UK if that is your timezone. Going to be a bit of a learning curve for you if new to both linux and Gimp.
Gutenprint looks like this.
packing in for the night.
