It is currently Mon Sep 21, 2026 10:02 am
 Post subject: Hello all
PostPosted: Sat Oct 30, 2021 4:20 pm  (#1)
Hi and thanks for having me.
I have been using Gimp to process my astrophotography images. My reason for signing up is that I need some better tool to remove gradients - Gimp's gradient tool is too limited and ends up introducing new gradients. I need to select points representative of the background gradients and do a polynomial interpolation so I can be done in one sweep.
My plan is to do this in Python. I'm a bit concerned as there are few documentation links to the Python interface so I'm hoping it is not deprecated. Then, can I use it with Python 2.7 or Python 3 and what if I need numpy, can I use an Anaconda installation?
Any recommendations are welcome.
Henk
 Post subject: Re: Hello all
PostPosted: Sat Oct 30, 2021 7:05 pm  (#2)
Have you tried: Color> Components> Extract Component or, Color> Components> Decompose?
PostPosted: Sat Oct 30, 2021 7:05 pm  (#3)
Henk
I think there are a handful of people here, that might know what you're looking for.
Welcome to Gimp Chat HenkSB.
Please feel free to elaborate further within the forum about your usage of Python.
PostPosted: Sat Oct 30, 2021 7:53 pm  (#4)
Yes I have. It is not very helpful because the information is only displayed for one color at a time which makes the problem three times harder IMHO. A color gradient is a continuous function in 3 dimensions and can be manipulated in one combined figure. I don't mind that part of the current gradient removal. The problem is that the gradient is constructed in parallel lines which is inadequate for my purpose.
Another place where something similar bugs me is the Curves dialog. I use that more than anything else especially for color balancing but I find it hard to use. What is lacking is a separate color balancing dialog like Deep Sky Stacker has where the histograms can be manipulated while seeing all color histograms in one figure. Seeing one histogram at a time as the Curves dialog does, makes it much harder. It would be helpful if such a dialog existed. Also, a log scale in the X direction would be nice for astrophotography because on a 32 bit scale the photons for faint nebulosity are all the way to the left.
And last on my wish list is something to make stars smaller. Erode works but when you apply it a few times it starts breaking up. Luckily there is a tool named StarNet++ that removes all stars and is helpful to fix such issues because you can edit the stars separately. That's all!
PostPosted: Sat Oct 30, 2021 10:09 pm  (#5)
Welcome to gimpchat,
Did you tried Filters/Distorts/Value propagate... ? https://docs.gimp.org/2.10/nl/gimp-filt ... agate.html
It works by 1pixel (Ctrl+F to repeat as needed), for smaller stars maybe try "Mode black", in all case you will need to tinker and experiment.
Value propagate works well on a mask as well.
Patrice
PostPosted: Sat Oct 30, 2021 11:32 pm  (#6)
Welcome HenkSB to Gimp Chat. :)
Make your 5 posts quickly then you can post an image for us to look at - let us know what needs to be done to it and we will try to do it giving you the directions to do so, using gimp.
PostPosted: Sun Oct 31, 2021 11:28 am  (#7)
That's very nice, thanks! So, since a moderator is asking, here's post 3...
PostPosted: Sun Oct 31, 2021 11:28 am  (#8)
And post 4...
PostPosted: Sun Oct 31, 2021 11:29 am  (#9)
And post 4...
And post 5. Next up will be an image. Sorry about the spam!
PostPosted: Sun Oct 31, 2021 12:00 pm  (#10)
Here's an image. I stretched it in DSS (Deep Sky Stacker) quick and dirty, no smoothing, and saved it in Paint as JPG to reduce the size.
The image has purple, blue and green hues in various directions. I know I can fix it by using gradient removal, I have vast experience with that, but it's not what I want because I have to do this all the time, it also creates gradients and it is just too much work. I would like to have control over where the interpolation is done by selecting non-star and non-nebulosity areas, individual points if I have to.
My typical workflow is to start with the stacked image (this one has 60 x 2 minute ones I believe and has been stacked with flats and bias frames in DSS, from a Redcat51 with an ASI2600MC on an AVX). The result is a 32 bit image that has to be stretched at least once to see enough detail. I use curves for that. It is important to keep the white point where it is or else you blow out the core. During the stretching usually the gradients show up from light pollution of the city and the neighbors.
Sometimes I'll remove all stars using StarNet++ so I can work on the nebulosity without messing up the star colors, then blend the stars back in through a new layer. Sometimes I use a star mask using Threshold and a manual selection (with value inversion and multiplication) to blur out all non-star and non-nebulosity parts then subtract it to remove the gradients. But star masks have side effects (ringing stars).
Gradient removal is important. There is a plugin for PS named Gradient xTerminator that is sold commercially and does only that, there is IRIS that does it, others use Astro Pixel Processor, pixInSight, or AstroArt, usually a variety of editors to get the job done. I prefer to use just Gimp and want to see what I can achieve with Python.
Thanks for helping out!
PostPosted: Sun Oct 31, 2021 12:27 pm  (#11)
Welcome to the forum! :)
PostPosted: Sun Oct 31, 2021 12:49 pm  (#12)
I did a quick try and was impressed in first instance but when I zoomed in I noticed the same as with repeated Erode namely it creates square blobs and distorts the stars significantly. Here's an example,
Thanks for the advice though, I may end up using it.
PostPosted: Mon Nov 01, 2021 2:20 am  (#13)
DCP Dehaze will get rid of most of it It's in the plugin GMIC under details
Or you could try levels in gimp
you could also try
duplicate layer, then use burn/linear burn mode
PostPosted: Mon Nov 01, 2021 11:39 am  (#14)
Thanks SallyAnn for trying to solve this! The result is a rather orangey though, it looks liek you pulled out all blue from the nebulosity.
I just finished a Scilab script that does the job very well. Let me show what it does in steps. Here's the original image:
Basically, I did a Free Select around the nebula in Gimp, filled it in with white, then did a Threshold to select most of the stars, then a Value Invert to return the negative mask to basically selects the non-stars. It looks like this:
If you look closely you can see a new line introduced, this is because I did the thresholding in two steps based on the star density. The math will take the average of the non-black areas eventually so it does not affect the gradient intensity later on. The basic image for gradient estimation is obtained by multiplying the original image with this mask:
Then I ran the gradient estimator that I wrote in Scilab. It is based on a least squares estimate using Chebyshev polynomials (for numerical robustness). I tell it how many data points I want for each polynomial parameter. Based on this, it chops up the image in cells, also accounting for the blacked-out area. It collects the average data for each cell and also constructs the Chebushev regression variables for it. Then it performs a least squares for each color and composes the estimated gradient. It looks like this:
... oh shoot, 3 images is the maximum. Let me post this then continue.
PostPosted: Mon Nov 01, 2021 11:44 am  (#15)
So here's the resulting estimated gradient:
Subtracting this from the original (after maximizing the gradient to the old image to prevent negative values where the gradient values are larger than the original, I get the image with gradient removed:
This is quite nice! I don't know if this is beginner's luck but my Scilab script worked wonderfully on this example.
The reasone why I picked Scilab and not Python is because Scilab is made for math and avoids the complexities of using numpy and scipy. Furthermore, Gimp's Python does not have those anyway. I suppose I could write a Python wrapper to call Scilab from Gimp so I can keep working with the Scilab script. Let me see how this works out.
PostPosted: Mon Nov 01, 2021 12:36 pm  (#16)
Actually I just improved it a little. In my fiirst try I included all blacked-out areas in the least squares estimation, which was unintended, and makes the gradient dive down in those areas. As a result it maintains too much nebulosity around the borders. Here's the fixed version, gradient and final image.
PostPosted: Mon Nov 01, 2021 9:31 pm  (#17)
I think you are doing a hell of a great job with the Andromeda galaxy, you also got a very nice definition of M32 and M110, the result is gorgeous! :clap
Patrice
PostPosted: Wed Nov 17, 2021 4:51 pm  (#18)
Hello! I am Valentina came to you to learn more about the Gimp. I really like working here, but I don't know much yet. I have version 2.8 for the latest version so far I do not dare to switch.
PostPosted: Wed Nov 17, 2021 9:10 pm  (#19)
