It is currently Sat Nov 07, 2026 11:30 am
Post new topic Reply to topic  [ 120 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
 Post subject: GIMP 2.8.12/14 Released (update)
PostPosted: Mon Aug 25, 2014 5:38 pm  (#1)
Looks like there are still some issues with the Official Installer.
We have released an updated 2.8.14 installer (http) for Microsoft Windows. This one fixes the crash on window resize and the missing icons bugs - all by updating the included GTK+ library to 2.24.24.
Still unsolved are the missing spacing character in the zoom drop down and the disappearing background on high zooms (updating the Pango and Cairo libraries that are didn't change anything there), investigations continue.
Please continue to report bugs, we can't fix what we don't know about.
http://www.gimp.org/
GIMP 2.8.14 has been released. This is a bugfix release in the stable 2.8 series, no new features were added.
Yesterday's 2.8.12 release had broken library versioning, please don't distribute any binaries of 2.8.12!
For a complete list of changes since 2.8.12 please see the "Changes" section below. Also see the release notes of the 2.8 series at http://www.gimp.org/release-notes/gimp-2.8.html
Happy GIMPing,
--Mitch
Download
GIMP 2.8.14 is available from:
http://download.gimp.org/pub/gimp/v2.8/
and from the mirrors listed at:
http://www.gimp.org/downloads/#mirrors
Please use the torrent, it distributes
the download bandwidth across all mirrors:
http://download.gimp.org/pub/gimp/v2.8/ ... z2.torrent
Overview of Changes from GIMP 2.8.12 to GIMP 2.8.14
General:
- Fix libtool versioning (forgot to bump gimp_interface_age)
Overview of Changes from GIMP 2.8.10 to GIMP 2.8.12/14
Core:
- OSX: Fix migration code for old GIMP directories
- Fix brush sizes when used from plug-ins
- Windows: Allow to Explorer-open files with UTF-8 characters in the filename
- Make XCF loading more robust against broken files
GUI:
- Make sure the widget direction matches the GUI language
- Remove the option to disable the warning when closing a modified image
- Fix canvas overlay widgets (like the text options) for tablets
- Make DND work between images in one dockable
Libgimp:
- Make gimp_image_get_name() return the string used for the image title
Plug-ins:
- Make script-fu-server more secure by listening to 127.0.0.1 by default and add a warning about changing that IP. This breaks the procedure's API, but for security reasons.
- Bring back proper script-fu translations
General:
- Massively clean up and fix the OSX build and bundle
- Add Jenkins tutorial
- Documentation updates
- Bug fixes
- Translation updates
Release notes of the 2.8 series at http://www.gimp.org/release-notes/gimp-2.8.html
 Post subject: Re: GIMP 2.8.12 Released
PostPosted: Mon Aug 25, 2014 6:07 pm  (#2)
You're kidding!? :jumpclap
PostPosted: Mon Aug 25, 2014 6:16 pm  (#3)
Cool. I'll wait for feedback before I download an install, haha.
PostPosted: Mon Aug 25, 2014 7:14 pm  (#4)
No windows builds yet; hope it didn't break anything. (I know; cynical remark;lol). :)
PostPosted: Mon Aug 25, 2014 7:44 pm  (#5)
I downloaded the torrent and extracted gimp. I have no idea how to install it with all those files inside the folder. :oops: :oops: :roll:
PostPosted: Tue Aug 26, 2014 1:59 am  (#6)
Molly it was in Ubuntu software centre already check your Fedora repository.
My mistake I had it listed in the repository ppa:otto-kesselgulasch/gimp not Ubuntu software centre.
PostPosted: Tue Aug 26, 2014 5:44 am  (#7)
ok, thanks Odin
PostPosted: Tue Aug 26, 2014 7:29 am  (#8)
Wow i just noticed there is an updated Perl build (fork) now.
https://git.gnome.org/browse/gimp-perl
PostPosted: Tue Aug 26, 2014 7:38 am  (#9)
Windows builds should be available tonight. I haven't heard yet on the MacOS builds.
I'm glad that dragon drop between image tabs is now working. I may start using single window mode more (it is amazing how accustomed one becomes to having a feature).
PostPosted: Tue Aug 26, 2014 8:14 am  (#10)
Where do I find the repository in Fedora? The Gimp-2.8.12 update is already available in Ubuntu
PostPosted: Tue Aug 26, 2014 10:21 am  (#11)
D&d between image tabs has been working in 2.8.10 (well, at least in Windows version, it has).
Did you mean layers d&d over image tab is working in 2.8.12?
Mitch said this feature won't be available till 2.10 but it was almost 2 years ago.
PostPosted: Tue Aug 26, 2014 10:28 am  (#12)
After it's been successfully compiled, the new GIMP update will be installed automatically when you update Fedora (unless you skip or block it).
Unfortunately, GIMP 2.8.12 failed to compile on koji (Fedora's build system). I'm not sure what the problem was but it failed to compile across all supported Fedora versions. See here. The red dash on the right column denotes a failed compile attempt.
I have not tried to compile myself but I'll give it a shot later on today.
PostPosted: Tue Aug 26, 2014 10:47 am  (#13)
https://git.gnome.org/browse/gimp-perlPerl
Is this for Windows?
PostPosted: Tue Aug 26, 2014 10:51 am  (#14)
Thank you Tux, I am sure it will be fixed very soon knowing how perfect Fedora runs 99.99999999 percent of the time
PostPosted: Tue Aug 26, 2014 12:15 pm  (#15)
There may be a glitch in this release so if you haven't updated yet then you might want to hold off for a little while.
If you've already installed 2.8.12 then you may as well leave it until the fix is released. As I understand the problem, it will only affect the compiling of plug-ins using gimptool; plug-ins that have already been compiled should be fine.
EDIT: 2.8.14 released. See first post by GNUtux.
PostPosted: Tue Aug 26, 2014 12:27 pm  (#16)
Thank you Saul
 Post subject: Re: GIMP 2.8.12 Released (BROKEN) - GIMP 2.8.14 Released
PostPosted: Tue Aug 26, 2014 1:06 pm  (#17)
Looks like GIMP 2.8.12 was broken and GIMP 2.8.14 has now been released.
See first post for details.
PostPosted: Tue Aug 26, 2014 1:08 pm  (#18)
Early adopters always get burned. lol
Glad my inability to compile saved me from a lot of headaches then. lol
PostPosted: Tue Aug 26, 2014 1:08 pm  (#19)
:tyspin
PostPosted: Tue Aug 26, 2014 3:06 pm  (#20)
Molly, GIMP 2.8.14 compiled clean on my Fedora 20 install.
It also compiled across all current Fedora versions so it should appear in the update repos soon.
There were several changes made to the script-fu plug-in, so I suppose I'll need to create a new patch for the Script-fu scrolling interface. Version 1.0 of the scrolling interface works but it's missing the new code included GIMP 2.8.14.
