It is currently Sat Nov 07, 2026 10:21 am
 Post subject: mathmap kaleidoscope not working
PostPosted: Fri Oct 10, 2014 12:25 am  (#1)
For some reason I am able to use every expressions in Mathmap (Gimp 2.8) except kaleidoscope. All I get is a solid black picture. I used this expression before (on other computers). Tried different pictures and the result is the same. Any ideas?
 Post subject: Re: mathmap kaleidoscope not working
PostPosted: Fri Oct 10, 2014 8:55 am  (#2)
Try setting the center X and Y to 0.5
PostPosted: Fri Oct 10, 2014 9:07 am  (#3)
Seems to be fine with the 64 bit plugin.
PostPosted: Fri Oct 10, 2014 11:20 am  (#4)
some tips
1. in user value the setting RAD shoud be other then ZERO (better 0.5><1.5)
2.you can use also Gmic>Deformations>Kaleindoscope ( 3 types)
PostPosted: Fri Oct 10, 2014 11:25 am  (#5)
Same result.
PostPosted: Fri Oct 10, 2014 11:40 am  (#6)
Marcello wrote:
some tips
For 1, no effect - still black (see screen capture). For 2, I don't have a Gmic. I've been using Gimp -> Filter -> Generic -> Mathmap -> Animation (or Map) -> Kaleindoscope. I tried all 3, same result.
PostPosted: Fri Oct 10, 2014 12:26 pm  (#7)
updating
1. that picture (Bellagio) is not working also in my PC
2. but is working in Gmic
3. other pictures are working in Mathmap kaleind.
PostPosted: Fri Oct 10, 2014 12:32 pm  (#8)
With the image as you posted I get a black image as well.
Adjusting the aspect ratio to nearer square (and rotating) I get a result
but probably not what you are looking for
PostPosted: Fri Oct 10, 2014 12:48 pm  (#9)
I was able to get the attached screenshot before. For the current purpose, I need to redo the picture but all I get is a "black"
PostPosted: Fri Oct 10, 2014 12:49 pm  (#10)
Marcello wrote:
updating
What's Gmic?
PostPosted: Fri Oct 10, 2014 12:54 pm  (#11)
ecs1749 wrote:
Marcello wrote:
updating
What's Gmic?
viewtopic.php?f=28&t=1477
PostPosted: Fri Oct 10, 2014 6:42 pm  (#12)
Marcello wrote:
ecs1749 wrote:
Marcello wrote:
updating
What's Gmic?
Ok, the Kaleidoscope from Gmic does work - but with a different result. At least it works.
PostPosted: Fri Oct 10, 2014 7:54 pm  (#13)
It seems to work OK with a small amount of cropping, then setting the Edge Behavior Y to Wrap.
PostPosted: Fri Oct 10, 2014 8:06 pm  (#14)
By "It", I presume that's MathMap, not Gmic, correct?
I don't have MathMap at work. Will try it when I get home.
Thanks,
PostPosted: Fri Oct 10, 2014 9:29 pm  (#15)
You would presume correctly. :)
PostPosted: Sat Oct 11, 2014 11:17 am  (#16)
Try setting the edge behavior y to wrap.
Then try these values.
That worked for me.
PostPosted: Sat Oct 11, 2014 11:21 am  (#17)
Cool image to play with in this filter by the way.
Sorry Tux didn't see your post before mine. :)
