It is currently Sat Nov 07, 2026 9:40 am
 Post subject: New on canvas IWARP tool.
PostPosted: Sat Jan 31, 2015 12:04 pm  (#1)
This is supposed to be available in the GIT Master. Has anyone compiled the latest GIT version and/or tested this?
Or is it available in GIMP-2.8.15?
I don't see anything here.
https://git.gnome.org/browse/gimp/
Or is that part of the unified transform tool?
 Post subject: Re: New on canvas IWARP tool.
PostPosted: Sat Jan 31, 2015 12:50 pm  (#2)
AFAIK this tool was for 2.10... What makes you think it is available in a 2.8 build?
PostPosted: Sat Jan 31, 2015 2:31 pm  (#3)
I thought anything available in the GIT master was available to compile.
Turn the IWarp plug-in into an on-canvas tool work in progress Will be part of 2.10 (available in Git master)
PostPosted: Sat Jan 31, 2015 3:02 pm  (#4)
Yes (this is the basic principle of Open Source), but not independently...
PostPosted: Sun Feb 01, 2015 9:04 pm  (#5)
The tool is called Warp Transform. If it's not in your toolbox, go to 'Edit > Preferences > Toolbox' and enable it.
PostPosted: Mon Feb 02, 2015 10:06 am  (#6)
Hiya prokoudine.
I don't see it there in GIMP-2.8.14. Toolbox list. :puzzled :)
PostPosted: Mon Feb 02, 2015 10:29 am  (#7)
I don't have it either, it just shows cage transform
PostPosted: Mon Feb 02, 2015 12:36 pm  (#8)
New features are never* backported from the development branch to the stable releases. The stable version is currently 2.8 and the only changes that will appear in any 2.8.x releases will be bug fixes.
* on very rare occasions, a minor new feature might be added if that is the sanest means of fixing a problem.
PostPosted: Mon Feb 02, 2015 12:51 pm  (#9)
@rod:
The only thing, that I can give you, is a modified iwarp plugin (windows - 64bit).
I rearranged the settings area, deleted the animation settings (I never used them)
and made the preview bigger. Only cosmetics...
I called it "liquify", but it is not comparable to the photoshop tool.
liquify.zip [23.46 KiB]
Downloaded 540 times
PostPosted: Mon Feb 02, 2015 1:07 pm  (#10)
liquify is one great PS plug-in, I wish it were available in Linux... maybe some day.
PostPosted: Mon Feb 02, 2015 1:24 pm  (#11)
Have you tried Tools | GEGL Operation | waves?
PostPosted: Mon Feb 02, 2015 1:54 pm  (#12)
Wot?
Oh, I see. No, liquify has nothing to do with a wavy effect.
Liquify is a plugin/tool that allows to deform parts of the image, just as iwarp does.
But I think, liquify works as the deformation tool of gimp-2.9.1 on the canvas.
Iwarp is nice, but iwarp uses the original size when using it on a small part of an image.
You can change the size of the plugin window, the preview stays the same size.
My modifications zoom the preview window according to the size of the plugin window.
By rearranging the settings area, I use as much space as possible for the preview area.
So it becomes more useful to me.
Hatti
PostPosted: Mon Feb 02, 2015 2:03 pm  (#13)
That is a cool tool Odin, I have never used it before... thanks.
PostPosted: Mon Feb 02, 2015 2:52 pm  (#14)
Hatti,
is there a version also for the "poor" 32-bits users?
PostPosted: Mon Feb 02, 2015 3:13 pm  (#15)
Yes, please, can you make a 32bits version of it ?
Liquify is an awesome tool on PS, there's a plugin for Paint.NET from the pyrochild plugin pack :
http://forums.getpaint.net/index.php?showtopic=7291
that emulate very nicely how good PS Liquify is. It's the major reason i still have Paint.NET on my system :D
PostPosted: Mon Feb 02, 2015 3:38 pm  (#16)
GEGL waves is not quite the same but fun. :)
Rumour has it this Warp Transform tool is replacing iWarp in 2.10.
PostPosted: Mon Feb 02, 2015 3:49 pm  (#17)
that would be nice. I think the iwarp tool is the worse tool in Gimp.
PostPosted: Mon Feb 02, 2015 5:53 pm  (#18)
Thanks for that info Saulgoode.
PostPosted: Mon Feb 02, 2015 5:56 pm  (#19)
Onkel Hatti wrote:
@rod:
Thanks Onkel. :) I believe i had this before on my old machine. Forgot all about it.
Off topic-
You wouldn't happen to have a newer (large preview) plug-in for Colors>Filter Pack would you? :)
PostPosted: Mon Feb 02, 2015 6:04 pm  (#20)
Nicely done Onkel. :)
