It is currently Sat Nov 07, 2026 9:41 am
 Post subject: Partha has just released updated compiles of both Gimp 2.8 and 2.9
PostPosted: Mon Apr 13, 2015 10:25 am  (#1)
Partha has just released updated compiles of both Gimp 2.8 and 2.9. There are both installer and portable versions available.
http://www.partha.com/
Per the website:
" I have updated Gimp 2.9 series to the git pull from today, April 12, 2015. The portable version has been updated as well. I think it has come a long way and I find it to be much faster than previous versions that I have packaged.
For the 2.8 series, I updated all the bugfixes as of April 12."
 Post subject: Re: Partha has just released updated compiles of both Gimp 2.8 and 2.9
PostPosted: Mon Apr 13, 2015 1:10 pm  (#2)
When Windows 32 bit?
One thought - according to me:
first 32 bit holders for the poor - then (for richer computer owners) 64 bit.
What are the statistics for Windows?
According to me, 40% of the 32 bit - do not forget us - poor people !!!
Although there is a solution - Linux.
I would like to have a choice - what system who will ...
PostPosted: Mon Apr 13, 2015 1:49 pm  (#3)
Per the website:
Thank you Partha. Did you get my email?
And thanks too you also bilbo9955. :)
PostPosted: Mon Apr 13, 2015 2:15 pm  (#4)
Cool the warp transform with dif tools has been added to the master. :)
Now if we could add the symmetry tool. hint hint
PostPosted: Tue Apr 14, 2015 5:21 am  (#5)
Please Partha. Why ?
:hoh
PostPosted: Tue Apr 14, 2015 1:11 pm  (#6)
Glad I could help
PostPosted: Sat May 09, 2015 7:01 pm  (#7)
May8 new 2.9.1 build released.
PostPosted: Sun May 10, 2015 1:09 am  (#8)
Per the website:
But no python it's a fail
PostPosted: Sun May 10, 2015 10:42 am  (#9)
Hi, can I have a separate copy of Gimp 2.8.14 and retain a copy of Gimp 2.6.11. ? the reason I ask is that Gimp 2.6. 11 is no longer available for download, so if i download 2.8 / 2.9 will 2.6 .11 be wiped. I find that 2.6.11 is a very nice version for photo manips. I am running win 7 x64.
PostPosted: Sun May 10, 2015 10:59 am  (#10)
While a Gimp 2.8.x installation does uninstall Gimp 2.6 the reverse is not true.
Once Gimp 2.8.x is installed you can then re-install Gimp 2.6.x
The mirrors are still there, not sure about Australia, sticking with educational establishments as the most reliable.
http://mirror.umd.edu/gimp/gimp/v2.6/windows/
or
ftp://anorien.csc.warwick.ac.uk/ftp.gim ... 6/windows/
A default installation installs to C:\Program Files\Gimp-2.0 (no space) or the x86 for 32 bit and on first run creates a profile gimp-2.6.
Never tried the 64bit versions.
PostPosted: Mon Jul 20, 2015 6:24 pm  (#11)
7/19/15 GMIC and gimp 2.9.1 updated .
