It is currently Sat Nov 07, 2026 2:03 pm
 Post subject: GEGL gets mipmaps, 71 new image processing operations
PostPosted: Mon Jun 15, 2015 8:35 am  (#1)
Some Gimp development report on libregraphicsworld !
http://libregraphicsworld.org/blog/entr ... ts-mipmaps
Though with the mipmap system not guaranteed to get in :
Experimental mipmaps support. If you are not familiar with mipmaps, here's the basic idea. Instead of working on a huge image in its entirety, an application generates a smaller version of the original image and processes it for preview. While you are evaluating the preview, it silently chews the real thing in the background. Again, it's an experimental feature currently not used by GIMP, whether it will prove to be GIMP 2.10 material depends on contributors activity.
I'm starting to be worried about how performance will be.
 Post subject: Re: GEGL gets mipmaps, 71 new image processing operations
PostPosted: Mon Jun 15, 2015 11:26 am  (#2)
Learned a new command; some moderate improvement with C2G too after doing so. I actually tried 8 but didn't see any difference so backed off to 4. This environmental variable has been there for a few years too but didn't know about it.
GEGL_THREADS=4
Thanks for the link. :)
