It is currently Sun Nov 08, 2026 8:07 am
 Post subject: Gimp 2.9.3 Portable 32 bits Windows
PostPosted: Fri Jan 01, 2016 11:55 am  (#1)
samj Créations
http://samjcreations.blogspot.it/search?updated-min=2015-01-01T00:00:00-05:00&updated-max=2016-01-01T00:00:00-05:00&max-results=33
 Post subject: Re: Gimp 2.9.3 Portable 32 bits Windows
PostPosted: Sat Jan 02, 2016 9:24 am  (#2)
Thanks for the update. Cage Transform still seems a bit buggy. Upon creating the nodes it proceeded to run the progress dial and then crashed GIMP-2.9.3.
PostPosted: Sat Jan 02, 2016 10:52 am  (#3)
The playground tools work great though. :)
seamless clone
n-point transform
handle transform
PostPosted: Sat Jan 02, 2016 11:20 am  (#4)
The help>Search and run command is interesting also. :)
AND the on canvas gradient tool is super cool. :)
PostPosted: Sat Jan 02, 2016 11:22 am  (#5)
The gradient tool is excellent now.
PostPosted: Sun Jan 03, 2016 4:35 am  (#6)
I just noticed for some reason the script-fus for "alpha to Logo and "Create Logos" are missing from the build. I re added them to Sams release and they work fine. I wonder why they were left out?
Aha i think it's because some of the PDB plugins are a little off on values. Bovination logo won't run at all because of the ambiance setting in bump-map-plug-in set too high. And some scripts call for gimp-levels when it should be gimp-drawable-levels instead of gimp-levels. Easy fixes though. :bigthup
bump-map-plug-in - ambiance = high output (1) instead of older high output value and levels is (1) instead of 255. This really doesn't make sense to me but oh well.
neon logo crashes GIMP-2.9.3 entirely.
PostPosted: Sun Jan 03, 2016 7:06 am  (#7)
There has been a flurry of updates just in the last day. GEGL twice.
The cage transform has not been working for some time.
From last year: http://www.gimpusers.com/forums/gimp-de ... formations
Maybe not universal and dependent on libraries because it also effects my Gimp 2.8.16 in PCLOS. Not much action on this, but it is a terrible tool anyway.
Some nice things, MyPaint brushes are working much better now and a search. Hit the / key brings up a search box. Click on an item to activate.
edit: oops - I see Rod already mentioned that one
I find 2.9.3 has actually gone back in terms of speed. Looks like you might need a cray super computer to use N-Point deformations
PostPosted: Sun Jan 03, 2016 11:10 am  (#8)
Hardly any python modules work in the new Samj version either. And she is using Python-2.7 so i don't know if its the deprecated PDB calls in the scripting itself or what. LayerFX.py has many, many errors. I've a feeling many older plug-ins will not work with GIMP-2.10. That will be sad.
