It is currently Sun Nov 08, 2026 8:08 am
 Post subject: New samj 2.9.3 build
PostPosted: Tue Jan 12, 2016 10:49 am  (#1)
samj has posted a new build on hew website. It is 64/32bit.
http://samjcreations.blogspot.it/2016/0 ... p-293.html
 Post subject: Re: New samj 2.9.3 build
PostPosted: Tue Jan 12, 2016 3:13 pm  (#2)
Thanks for the heads up bilbo9955! Testing it now. :)
PostPosted: Wed Jan 13, 2016 7:54 am  (#3)
Great job.
Samj just does not add icons brushes MyPaint (this is easily remedied - downloaded MyPaint and make up for the * .png)
Icon layout is probably better than the gimp-symmetry.
Edit: Samj completed.
Thanks.
PostPosted: Wed Jan 13, 2016 9:46 am  (#4)
After some use of the 64bit version, everything runs well. The only thing I would like to see is inclusion of all the extra filters, like in her previous builds. Maybe this is becoming problematic in this version.
PostPosted: Wed Jan 13, 2016 12:13 pm  (#5)
For the lazy - pack icon brush MyPaint in the annex.
To remove(error in the original Mypaint)
history 1-5.myb;
redbrush.myb
s008.myb;
watercolor.myb
Thanks.
Add png to Brushes_ for_MyPaint.png.7z [603.82 KiB]
Downloaded 398 times
PostPosted: Wed Jan 13, 2016 1:41 pm  (#6)
history 1-5.myb;
redbrush.myb
s008.myb;
watercolor.myb
Where do you install these new images?
PostPosted: Wed Jan 13, 2016 9:30 pm  (#7)
Hi Rod - in the folder containing the files *.myb
PostPosted: Wed Jan 13, 2016 9:34 pm  (#8)
You mean you can show the brush dynamic as a brush icon? Pretty darn cool. :)
PostPosted: Thu Jan 14, 2016 12:17 am  (#9)
Hi Lyle - it's just the principle MyPaint - x.png (icon) and x.myb (brush) must be in hand.
And one more note - the lack of some icons in the menu.
This is easily fixed - you can download and add to the appropriate directories plus gtkrc.
PS.Samj - if it had read it, add it in the next version.
I cordially greet my first teacher compilation :hi5
I'm missing you on this forum, but please can you come back :yes
Missing icon in the menu.7z [493.34 KiB]
Downloaded 349 times
PostPosted: Thu Jan 14, 2016 1:05 am  (#10)
With this build there are what looks like different applications...one being called just 'GIMP'. Do the others refer to a language etc. I have just opened the one just called GIMP and it looks ok for English. What are the others? I also had a 2.9.1 EN portable which was mostly English. Just answered my own question....they are for different languages.
Can I delete the ones not needed And if so which...I don't want to delete anything that may affect the one I'm using?
PostPosted: Thu Jan 14, 2016 1:26 am  (#11)
The panorama projection is cool.
PostPosted: Thu Jan 14, 2016 3:52 am  (#12)
I copied all of my scripts over to the scripts folder in 2.9.3. Found they are not working properly....throwing a lot of errors. Do they just need a change in the wording to allow them to be used in 2.9? (By the way there was no 'script-fu' tag at the top until I put something in the scripts folder.) I did not make another folder for scripts. The one I put them in is already in the folders in preferences. So path is there already.
I assume it will be the same with plugins, they will not work correctly straight away?
PostPosted: Thu Jan 14, 2016 4:55 am  (#13)
Thank you. I've been yearning to test this version.
Cheers.
PostPosted: Thu Jan 14, 2016 8:04 am  (#14)
Most logo and alpha to logo scripts will not work correctly.I believe most are the plug-in PDB calls.
Should be "(gimp-drawable-plug-in-name-here)" NOT "(gimp-plug-in-name-here)" and the number of parameters are also changed. You shouldn't add scripts or plug-ins to this build. Unless the plug-ins were compiled with the GIMP-2.9 src gimptool. Most python will not work either as those PDB calls have also been deprecated.
PostPosted: Thu Jan 14, 2016 8:10 am  (#15)
Thanks Rod. I can always move them out again.
Was hoping there might be a quick fix. means I don't have extras like layer effects etc. I haven't tried plugins but won't now as you said.
PostPosted: Fri Jan 15, 2016 3:17 pm  (#16)
Also you won't find Map Object in the filters menu. BUT you can go to Help>Search and find it there.
PostPosted: Mon Mar 28, 2016 4:56 pm  (#17)
New (28-03-2016) development version Gimp 2.9.3 Portable 32-bit and 64-bit Windows.
http://samjcreations.blogspot.it/2016/03/version-de-developpement-gimp-293.html
Merci Samj.
PostPosted: Tue Mar 29, 2016 1:08 am  (#18)
thanks Samj (and thanks MareroQ) !
Inside it is said that the first launch is very slow; I did it and it took just 15 seconds (not bad at all!).
I will do some experiment with it, thanks again.
PostPosted: Tue Mar 29, 2016 3:34 am  (#19)
There are Gimp scripts still being written that use deprecated calls, you just do not see them ;)
Not tried with Samj Gimp 2.9 (I use linux) You can try running Gimp 2.9 with the compatibility switch on
--pdb-compat-mode=mode
PDB compatibility mode (off|on|warn).
If the script/plug-in is going to work then that should stifle the deprecated function messages.
Otherwise there are differences that cause problems. No Lancos3 sharpening any more, so a script that calls that will fail. I have converted one or two scripts but hard going for me.
Maybe a repository of corrected scripts could be set up.
PostPosted: Tue Mar 29, 2016 3:39 am  (#20)
And if anybody does this, please indicate which version (GIT commit) of 2.9.3 it's been shown to work using, given that "2.9.3" is NOT a fixed version and is continually changing.
Kevin
