This script works with GIMP-2.9 so if you want to see all the new PDB calls for GIMP-2.9 for script writing and/or fixing just a heads up. I didn't think it would work as most other python modules won't.
It is found under the Help menu>Dump procedure
It creates an HTML layout of the PDB database. Pretty cool script and very helpful for fixing script issues.
Thanks codefox! Whoever you are.
PDB Dump-2.9.zip [1.33 MiB]
Downloaded 301 times
You need only unzip and open the INDEX.html file.
If you want the python file just PM me.
