It is currently Sun Nov 08, 2026 7:40 am
 Post subject: GIMP-2.8.18
PostPosted: Mon Aug 22, 2016 1:13 pm  (#1)
I heard this was released and i am wondering if anyone has installed this update? If so does it run well?
 Post subject: Re: GIMP-2.8.18
PostPosted: Mon Aug 22, 2016 1:31 pm  (#2)
Hi Rod,
I'm running 2.8.18, on Windows 10 64bits.
No noticeable problems so far.
PostPosted: Mon Aug 22, 2016 2:14 pm  (#3)
Welcome back Rod. :bigthup
Works fine with Linux 64 bit.
PostPosted: Mon Aug 22, 2016 5:04 pm  (#4)
Thanks all. I will give it a go then. Good to be back Odin.
PostPosted: Mon Aug 22, 2016 9:43 pm  (#5)
Hey Rod,
It works for me and I'm running it on Windows 7 64Bit.
PostPosted: Tue Aug 23, 2016 6:04 am  (#6)
mackenzieh wrote:
Hey Rod,
:tyspin mackenzieh.
PostPosted: Wed Aug 24, 2016 6:42 am  (#7)
I have updated from 2.8.10 to this one and it is doing ok so far.
on 32 bit Windows 10
PostPosted: Thu Aug 25, 2016 1:42 pm  (#8)
I'm running both Win 7 64 bit and Linux (SuSE 64 bit) and no problems here using 2.8.18
Also the latest g'mic is installed on both O/S's, and runs great (as always).
