It is currently Sun Nov 08, 2026 8:07 am
 Post subject: New GImp VER 2.8.20
PostPosted: Tue Feb 07, 2017 11:28 am  (#1)
New GIMP VER 2.8.20
New VER
Doron
 Post subject: Re: New GImp VER 2.8.20
PostPosted: Tue Feb 07, 2017 12:32 pm  (#2)
Sometimes better to wait and watch
http://www.gimpusers.com/mailmsg.php?85 ... pusers.com
PostPosted: Tue Feb 07, 2017 12:38 pm  (#3)
rich2005 wrote:
I agree.
PostPosted: Tue Feb 07, 2017 1:38 pm  (#4)
For me (Vista 32bit) Gimp 2.8.20 works very well - apart from the small problem with running the installer (because I have several versions of the GIMP ;) ).
PostPosted: Tue Feb 07, 2017 2:05 pm  (#5)
Ouch; I'll pass for now, then. lol
PostPosted: Tue Feb 07, 2017 2:20 pm  (#6)
Had no issues with installing & running 2.8.20
:gimp
PostPosted: Tue Feb 07, 2017 2:25 pm  (#7)
If you are running Win10 64-bit, TL, then please let us know. :)
PostPosted: Tue Feb 07, 2017 2:40 pm  (#8)
:yup
PostPosted: Tue Feb 07, 2017 3:31 pm  (#9)
I've come across this bug in every version starting from 2.6.
Seems as though this bug is still present in the previous 2.8 release.
I wonder if it's been fixed yet?
Crash While Using Color Picker
PostPosted: Tue Feb 07, 2017 3:53 pm  (#10)
GIMP 2.8.20 - Windows 10 x64 all the basic features working as expected including the color picker. Haven't found any bugs :mrgreen: yet.
:gimp
PostPosted: Tue Feb 07, 2017 7:01 pm  (#11)
GIMP 2.8.20 installed on notebook under Windows 10 x64.
AOK so far including the colour picker. Will wait a week or so before doing main PC.
PostPosted: Tue Feb 07, 2017 8:31 pm  (#12)
PostPosted: Tue Feb 07, 2017 9:23 pm  (#13)
2-8-20 loaded fine for me (win10), I had my 2-8-18 Installer,and a recovery file saved just in case
Take the plunge Lyle :yes
PostPosted: Tue Feb 07, 2017 11:38 pm  (#14)
This just in form bugzilla.gnome.org.
Looks like this bug wasn't fixed after all.
Bug 740634
Color picker crashes when there are multiple monitors
PostPosted: Wed Feb 08, 2017 12:57 am  (#15)
Works fine with single monitor though, maybe additional Ram would solve problem with multiple monitors
2-8-20 is a bugfix for 2-8-18, and I don't think Gimp would consider this to be a bug in the code
PostPosted: Wed Feb 08, 2017 12:59 am  (#16)
Thanks for the confirmation, TL. Regardless, I'll wait a few weeks to see what happens. :)
PostPosted: Wed Feb 08, 2017 12:36 pm  (#17)
I have Win 7, 64 bit (single monitor) at work, and it works fine here.
My lappy at home is Linux 64 bit, and no problems there so far either...
:D
(Never stop learning!)
PostPosted: Thu Feb 09, 2017 8:46 am  (#18)
I haven't updated since 2.8.16. :) Probably won't unless they add some new features or something.
PostPosted: Thu Feb 09, 2017 9:01 pm  (#19)
OK; you folks persuaded me to download the new GIMP. Will let you know of the success or failure shortly (25% downloaded so far; lol). :)
edit:
Well, G'MIC still works which is pretty much all I was worried about. ;)
PostPosted: Thu Feb 09, 2017 9:26 pm  (#20)
I figured Lyle wouldn't hold out too long, lol.
