It is currently Sat Nov 07, 2026 11:30 am
 Post subject: GIMP 2.10.0 Release Candidate 1 Released
PostPosted: Tue Mar 27, 2018 8:28 am  (#1)
You can find info here:
https://www.gimp.org/news/2018/03/26/gi ... -released/
Download:
https://download.gimp.org/pub/gimp/v2.10/
only Linux so far. Thanks to SAMJ for the info!
 Post subject: Re: GIMP 2.10.0 Release Candidate 1 Released
PostPosted: Tue Mar 27, 2018 1:07 pm  (#2)
AppImage now available:
https://github.com/aferrero2707/gimp-ap ... 4.AppImage
PostPosted: Tue Mar 27, 2018 3:29 pm  (#3)
From gimp.org
https://download.gimp.org/mirror/pub/gimp/v2.10/windows/
PostPosted: Tue Mar 27, 2018 4:08 pm  (#4)
The appimage works great and it picked up all my settings, Sweeeeet! Time to play...
PostPosted: Tue Mar 27, 2018 4:52 pm  (#5)
Can't seem to run G'mic on Gimp 2.10 via appimage.
Could not execute plug-in "gmic_gimp_qt"
(/home/racer/.config/GIMP-AppImage/2.10/plug-ins/gmic_gimp_qt)
because it uses an obsolete version of the plug-in protocol.
PostPosted: Tue Mar 27, 2018 5:18 pm  (#6)
The appimage that I linked to Runs fine with the included GMIC on Bodho 4.5 x64. If you are having a problem, report it here:
https://discuss.pixls.us/t/gimp-2-10-0- ... ad/7101/12
PostPosted: Tue Mar 27, 2018 6:37 pm  (#7)
Well the included G'mic wont run on my system. Linux Mint Cinnamon x64, which is based on Ubunto 16.04. In fact, a vast majority of all my plugins and scripts won't work either. I assume they need to be updated, though that's doubtful to happen.
I like version 2.10 a lot, but I'll have to keep v 2.8.16 along side for now.
PostPosted: Tue Mar 27, 2018 11:25 pm  (#8)
missing or faulty dll's a problem for me
PostPosted: Wed Mar 28, 2018 12:26 am  (#9)
As memory serves me correctly, when I installed 2.8.0, there were lots of bugs and compatibility issues with Script-fus that ran perfectly fine in 2.6x. Me thinks I'll wait until 2.10.2. lolol
PostPosted: Wed Mar 28, 2018 12:59 am  (#10)
Hello Gimp users
After some error messages of incorrect DLL
The software goes up and I can start checking it and playing.
Thanks
Doron.
PostPosted: Wed Mar 28, 2018 1:30 am  (#11)
Hello Doron,
I liked the icon theme you are using!
Can you please tell me where I can find it.
Thanks
Une
PostPosted: Wed Mar 28, 2018 2:44 am  (#12)
That appimage series, while aimed at being as universal as possible, has never been 100% on my Kubuntu 16.04 Added plugins either compiled or python either fail or are not recognised.
It is not a question of updating them, you would expect Ofnuts python scripts to work, there is something weird with the appimage.
I keep my own appimage, assembled using the ppa https://launchpad.net/~otto-kesselgulas ... gimp-edge/ and based on 'buntu 16.04 However that is frozen at 2.9.9 (Dec 2017) for 'buntu 16.x
Gimp code is using lots of updated packages these days. Hopefully there will be updates to 'buntu 16.04 in the future but I am not counting on it.
PostPosted: Wed Mar 28, 2018 4:35 am  (#13)
Installed (Windows-64).
If someone likes to have some of my python plug-ins ported, pls tell me here, I'm ready to do that.
Those ported to 2.9.9 run w/o error messages on 2.10-rc1.
PostPosted: Wed Mar 28, 2018 3:29 pm  (#14)
Yes dinasset, your scripts are the only ones that work on my gimp 2.10 RC1. I wouldn't mind if you ported BevelSelectedArea filter for one.
PostPosted: Wed Mar 28, 2018 11:08 pm  (#15)
une wrote:
Hello Doron,
Thanks
Une
The icon theme is inside the software/.
Goto to : EDIT --> Preferences --> Icon Theme And select COLOR ICONS
Doron
PostPosted: Wed Mar 28, 2018 11:35 pm  (#16)
Which filter are you referring to?
I don't remember one called BevelSelectedArea.
PostPosted: Wed Mar 28, 2018 11:43 pm  (#17)
Usage notes:
-G'MIC can't be added
-GEGL operations still w/o PDB interface
PostPosted: Fri Mar 30, 2018 4:11 am  (#18)
Got my G'mic problem in the appimage sorted out. Apparently it copied over my version of G'mic when I first ran the Gimp 2.10 appimage. Deleting it from my .config/AppImage/~ folder fixed the problem.
Now If someone could make BevelReflectLogo and Extrude scripts work in Gimp 2.10, that would be great....
PostPosted: Fri Mar 30, 2018 5:10 am  (#19)
Linux MLBevelReflect. It will work, but probably not with that appimage.
This in Kubuntu 16.04, Gimp 2.9.9 and ML-bevel-reflect: https://i.imgur.com/bHIsIfI.jpg
Scripts for extrusion? Some work / some do not: An old script-fu still gets there: https://i.imgur.com/rXKg9Ts.jpg
PostPosted: Fri Mar 30, 2018 5:28 am  (#20)
Neither of those scripts work in this appimage. Maybe the full stable version of Gimp 2.10 will work when it is released. Hopefully it will.
Playing around with the ToneMap filters. They are very slow,but give good results.
