It is currently Sat Nov 07, 2026 7:48 am
 Post subject: 2.10.4 released (almost)
PostPosted: Thu Jul 05, 2018 6:45 am  (#1)
Gimp News 2.10.4
Awaiting servers to update.
Now updated: https://download.gimp.org/pub/gimp/v2.10/windows/
:gimp
 Post subject: Re: 2.10.4 released (almost)
PostPosted: Thu Jul 05, 2018 8:29 am  (#2)
Thanks for the info!
PostPosted: Thu Jul 05, 2018 3:32 pm  (#3)
Gimp 2.10.4 Appimage was released today and I'm currently running it. https://github.com/aferrero2707/gimp-ap ... 4.AppImage
PostPosted: Thu Jul 05, 2018 8:32 pm  (#4)
Downloading it now; hope some of the weirdness has been addressed. :)
PostPosted: Fri Jul 06, 2018 12:07 am  (#5)
Ofnuts add-on collection manager working properly with version 2.10.4, so far! :hehe Glad to have that back, really missed that plug-in. :gimp
PostPosted: Sun Jul 08, 2018 12:56 am  (#6)
Samj package now available, both for 32 and 64 bits.
https://samjcreations.blogspot.com/2018/07/
PostPosted: Sun Jul 08, 2018 1:42 am  (#7)
Just downloaded/installed the 64-bits version.
Tried one of my 2.10 filters, it works but I get a bit annoying warnings after launching it; should I do something? or should I simply accept then?
PostPosted: Sun Jul 08, 2018 11:52 am  (#8)
I tried to download from Samj's but error: file has been interrupted. Tried several times. Will wait for awhile.
PostPosted: Thu Jul 12, 2018 12:14 am  (#9)
Samj published an update of her package 2.10.4.
There are some changes in the structure, for instance it imports all the preferences you have for 2.8, hence -if you do not like that, like me- you have to rename your .gimp-2.8 folder to avoid the import. It starts using a .bat, in the system Language, if you prefer to use English you have to change the Gimp Language preference (i.e. there aren't different exe launchers in different languages). Likely it works only for 64 bits (I have a 64 bits system, so no problem for me).
Tested on one of my filters and no more warnings! Good.
PostPosted: Sat Jul 14, 2018 5:55 am  (#10)
Sylvie & Michel (samj) released a new package for 2.10.4.
The different launchers in various languages are back (no need for a .bat).
Linked all my ported filters without any warnings.
Tried one and it ran perfectly.
Should work for both 64 and 32bits (but I can't test this aspect, someone else hopefully wil do it).
