It is currently Sun Nov 08, 2026 7:02 am
Post new topic Reply to topic  [ 82 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: Introducing Gimp 2.7.3
PostPosted: Sat Apr 30, 2011 6:09 pm  (#1)
Looks like I was beaten to the punch so to speak. :) :gaah
Well, the reason I had not announced it yet myself was that I wanted to create an installer and keep a promise made to some of you a while ago to post the technical details. I now have achieved one of the two. The hard drive version now comes with an installer which will create all the necessary paths etc. It will also create a desktop icon for your convenience.
You can also uninstall from the Control Panel as any other program.
Caveats: I don't know how it will work on your machine. I have tested on XP and Windows 7 (32-bit and 64-bit) US locale. PhotoComix has tested the portable version on his machine and it works.
Give it a whirl and see if it works for you. As always, feed back welcome!
Download at www.partha.com
Thanks,
Partha
 Post subject: Re: Introducing Gimp 2.7.3
PostPosted: Sat Apr 30, 2011 6:58 pm  (#2)
i was just playing with the new built ...no problem till now
PostPosted: Sat Apr 30, 2011 6:59 pm  (#3)
Partha, when did you add the Installer to the GIMP 2.7.3? Earlier today? Just a few minutes ago?
I'm back I think
PostPosted: Sat Apr 30, 2011 7:04 pm  (#4)
Hi Willy,
Just a few minutes ago. Hot off the press so to speak. :)
Can you check the installer if you can? I don't have a Vista machine and so don't know how it will behave.
Thanks,
Partha
PostPosted: Sat Apr 30, 2011 7:06 pm  (#5)
Hi PC,
You may have noticed (or did I already tell you?) that I did not include the larger previews that you had provided me. The reason is that they don't compile properly anymore and so you will need to a) modify them for the new builds or b) provide me with diff files so I can patch the source before building.
Thanks,
Partha
PostPosted: Sat Apr 30, 2011 7:11 pm  (#6)
Worked for me :D
Now hopefully themes will work
I'm back I think
PostPosted: Sat Apr 30, 2011 7:14 pm  (#7)
Theme Worked just like it did in 2.7.2 not messing around with Theme Switcher anymore
I'm back I think
PostPosted: Sat Apr 30, 2011 7:18 pm  (#8)
Willy wrote:
Worked for me :D
So the installer worked right off the bat?? Great! You know that it comes with an uninstaller. You can check for it in your Control Panel.
Thanks!
Partha
PS: Feel free to PM or leave me feedback on my site if you have any issues.
PostPosted: Sat Apr 30, 2011 7:19 pm  (#9)
Partha yes the installer worked great :D
Also, any chance in a future release you could have a working Theme Switcher? They always seem to not work for me :/
I'm back I think
PostPosted: Sat Apr 30, 2011 7:27 pm  (#10)
Well, I am going to try. Though I have a few priorities before that:
1. Technical details on the website.
2. MathML
3. Separates (64-bit)
4. Theme Switcher (though I have to first check it out myself).
Thanks,
Partha
PostPosted: Sat Apr 30, 2011 7:30 pm  (#11)
Just give me a hollar if you need any more Vista Testing done
I'm back I think
PostPosted: Sat Apr 30, 2011 7:34 pm  (#12)
Yay, even a portable version. Thank you so much!! Downloading it now. :mrgreen:
Oh and thanks for planning to look into the theme switcher. I've had troubles with it too when I tried 2.7.1.
PostPosted: Sun May 01, 2011 3:22 am  (#13)
...wonders about a mac version
PostPosted: Sun May 01, 2011 5:43 am  (#14)
Hi,
I have not looked into building a Mac version yet. See my priorities a couple of posts back. Perhaps with the technical details someone will step forward. Otherwise, I will look at it at a later time.
Thanks,
Partha
PostPosted: Sun May 01, 2011 5:53 am  (#15)
In case I overlooked something...
Is it possible in single windows mode to put the toolbox to the right?
Does anyone know if that polaroid preview window of another image, because you cannot look at two images at the same time, is implemented and I haven't seen it yet?
If they came to their senses (No offence, but I strongly disagree with the otherwise so smart developers here.) about being able to have two image and open side by side and be able to work with both at once?
If the thumbnail images that you see on top will be a list of what images you had open previously or if it will stay the way it is now?
Is it possible to move around that little window that opens on canvas when you open the text tool?
Is there a way to move text around when editing?
Or can I just turn, on canvas text editing off altogether?
PostPosted: Sun May 01, 2011 6:16 am  (#16)
postive post. I feel like I'm just complaining. :oops:
Love the new features :mrgreen: , just struggling with the text editor right now.
PostPosted: Sun May 01, 2011 6:51 am  (#17)
Former Member
Well looks like I need to take some time into getting introduced to this new UI.
Nice work!
PostPosted: Sun May 01, 2011 7:06 am  (#18)
Nice work!
Thanks! :)
Let me know if you have any issues.
PS: Can you post a screenshot of the new UI? I don't see a new UI on my machine. :(
PostPosted: Sun May 01, 2011 7:57 am  (#19)
Former Member
I didn't use 2.7.2 and I hardly used the official 2.7.1 release. (I did a couple times for the rotation on the brush, and now there's more so I'll be using this for awhile)
I noticed already some things I really don't like.
I clicked on layer modes and I haft to hold my mouse down for that list to stay up.
PostPosted: Sun May 01, 2011 9:25 am  (#20)
I did for a while too, the way I get around that bit of a mistake by Devs, is having the Move tool on Move Active Layer (not default option), then just switching to it to move text when it is needed.
Kind of a Pain but it works
I'm back I think
