It is currently Sat Nov 07, 2026 7:57 am
 Post subject: Gimp 2.10.06 is Released
PostPosted: Mon Aug 20, 2018 1:12 pm  (#1)
Hi Gimp Users
Gimp 2.10.06 Released
Doron
4X5DF
 Post subject: Re: Gimp 2.10.06 is Released
PostPosted: Mon Aug 20, 2018 3:31 pm  (#2)
Doronf2,
Gimp 2.10.6 may be released, but the download link on gimp.org still links 2.10.4 as the recent download.
PostPosted: Mon Aug 20, 2018 4:14 pm  (#3)
Download Link
PostPosted: Mon Aug 20, 2018 4:46 pm  (#4)
TimeLord wrote:
The links listed for August 20th don't make sense. Which one should be downloaded?
PostPosted: Mon Aug 20, 2018 5:20 pm  (#5)
Assuming you're running Windows, the second from the bottom is the one you want.
PostPosted: Mon Aug 20, 2018 5:36 pm  (#6)
Apparently Gimp 2.10.5 that I have, must be a pre-release version of Gimp 2.10.6 because it has the vertical text option....
PostPosted: Mon Aug 20, 2018 5:44 pm  (#7)
Thank you Racer-x. Yes, I am running Winodws.
PostPosted: Mon Aug 20, 2018 5:56 pm  (#8)
I don't have 2.10.5... I'm still running 2.10.4
PostPosted: Mon Aug 20, 2018 11:00 pm  (#9)
Just installed it; seems stable enough, but I had to re-add a DLL (Focusblur) since the installer removed it from the GIMP's directory where I installed the plugin. No biggy; plugin worked after I did so. :)
PostPosted: Tue Aug 21, 2018 2:31 am  (#10)
I like Vertical text
Doron
PostPosted: Tue Aug 21, 2018 3:38 am  (#11)
Which is why the recommend place for you own plugins in the user profile :)
PostPosted: Tue Aug 21, 2018 12:38 pm  (#12)
True, but if I put it there, the plugin did crash for me in older versions of 2.10x, ofnuts. Haven't tried to see if that got fixed. :)
PostPosted: Wed Aug 22, 2018 12:11 am  (#13)
OK; just toying with GEGL's little planet preset. Cool stuff. Now if I had Wallace's camera, this would look much better. :)
PostPosted: Wed Aug 22, 2018 12:19 am  (#14)
OK; decided to not use Mercator, but just make the edge seamless. :)
PostPosted: Wed Aug 22, 2018 12:32 pm  (#15)
How do I update via flatpak? Is that a complete reinstall?
PostPosted: Wed Aug 22, 2018 7:05 pm  (#16)
I don't use flatpaks anymore, I switched to AppImages instead. Mostly because of the huge amount of space needed for flatpak dependencies. Flatpak should update on it's own, at least that is what mine did when I used it. If not try something like flatpak update in terminal.
