It is currently Tue Nov 17, 2026 1:05 am
 Post subject: Astronomy plugin has been updated for Gimp 2.10
PostPosted: Mon Sep 24, 2018 5:21 pm  (#1)
Hi everyone, I'm here to announce that the Astronomy plugin from Georg Hennig has been Updated on both Windows and Linux, for the new Gimp 2.10 version . Just go to his website @ http://www.hennigbuam.de/georg/gimp.html , go to the bottom of the page and click on the download files and zip.
 Post subject: Re: Astronomy plugin has been updated for Gimp 2.10
PostPosted: Tue Sep 25, 2018 3:00 am  (#2)
good to know, thank you.
Regards
nelo
PostPosted: Tue Sep 25, 2018 7:11 am  (#3)
Thank you very much, Pocholo. Nice of you to share your information.
PostPosted: Tue Oct 30, 2018 6:28 pm  (#4)
The windows zip seems to be missing the lib folder as GIMP is asking for libgsl-23.dll.
The install file says to extract to lib folder but there no lib in the zip.
That might be for building/compiling, my problem might be because I am using Partha 2.10.6.
PostPosted: Wed Oct 31, 2018 1:18 am  (#5)
I have both, Gimp 2.10.6 (gimp.org Original version) and Partha's version in my PC. I have one in "Program File (x86)" and the Partha's version in "Program File".
And you're right. Partha's version doesn't have the folder 32, that is where the libgsl-23.dll reside.
What I did to make it work:
1. Copy the folder 32 from the Gimp 2.10.6 (gimp.org Original version) and paste it on the Partha's vesion on the folder gimp (C:\Program Files\GIMP-2.10.6-std/gimp).
2. Create a new folder in the Personal gimp directory: C:\Users\YourName\AppData\Roaming\GIMP\2.10\plug-ins and name it "Astronomy".
3. Open the "gimp-plugin-astronomy-0.10". Open the folder "gimp", open each of the folder subfolder, copy and past into the new "Astronomy" folder you just created.
4. Open the Script folder and copy the content, then go to:
C:\Users\YourName\AppData\Roaming\GIMP\2.10\scripts and paste.
5 Re-start Gimp and the location is: Filters/Astronomy
PostPosted: Sun Mar 29, 2020 10:50 am  (#6)
Hello everyone
I have installed GIMP 2.10.18 on Windows 10 (it is my first installation, no od version then in my computer) and the copied the astronomy plugins and scripts in programme/Gimp/ etc...in the folders .../lib/plugins and .../share/scripts. When starting GIMP four plugin s are not properly started by GIMP with the message "lib-gsl23.dll" missing. I tried to download this dll from the web but got a warning message that this file was infected.
Have you an idea or advices of what to do to make these plugins work ?
ALP73
PostPosted: Sun Mar 29, 2020 4:41 pm  (#7)
Hi ALP73, I know what you mean, I had the same problem. That file got upgraded to lib-gsl24.dll and now
lib-gsl25.dll, back when the new version GIMP 2.10 was created. I took mine from the old version GIMP 2.8 before I upgraded to 2.10 and I place the file where the new. Here is a lib-gsl23.dll copy. Just place it in the folder; C:\Program Files\GIMP 2\bin with the new one and "Astronomy plugin" will work. Good luck and stay safe!
libgsl-23.zip [930.49 KiB]
Downloaded 525 times
PostPosted: Wed Apr 08, 2020 2:14 pm  (#8)
How to install it in Gimp in MacOS
PostPosted: Wed Apr 08, 2020 10:17 pm  (#9)
Hello baryah and welcome to the forum.
Unfortunately,
this plug-in would need to be compiled for Mac specifically.
AFAIK, this has not been compiled by the creator,
to include a package for Mac OS.
Mac/Installing Plugins
System-wide script-fu scripts are stored in:
/Applications/GIMP.app/Contents/Resources/share/gimp/2.0/scripts/.
Executable and python plugins are located in:
/Applications/GIMP.app/Contents/Resources/lib/gimp/2.0/plug-ins/
User-private plugins are stored under:
$HOME/Library/Application Support/GIMP/2.8/plug-ins/.
NOTE: Check "Preferences > Folders" to confirm your plug-ins directory.
The information above,
concerning the installation of plug-ins within Mac OS.
Was obtained from the link below.
https://en.wikibooks.org/wiki/GIMP/Installing_Plugins
