It is currently Sat Nov 07, 2026 7:53 am
 Post subject: GIMP 2.10.11 portable SAMJ is out
PostPosted: Fri Apr 12, 2019 2:14 pm  (#1)
Just released.
Installed and made my first test: everything OK.
http://www.aljacom.com/~gimp/Gimp-2.10. ... 0190412.7z
 Post subject: Re: GIMP 2.10.11 portable SAMJ is out
PostPosted: Fri Apr 12, 2019 4:14 pm  (#2)
Thanks for the heads-up dinasset.
:hi5
PostPosted: Fri Apr 12, 2019 4:18 pm  (#3)
Hey dinasset. Because script-fu.exe with scrolling interface breaks a bunch of script-fus do you think SamJ would consider re compiling it for 32 and 64 bit GIMP-2.10? I tried to set up another build/compile environment but i haven't had any success yet. Still working on it though. ;)
:ninja
By the way i have the old c src files if she needs them.
PostPosted: Fri Apr 12, 2019 7:14 pm  (#4)
Just FYI, odd numbered versions are experimental and even numbered versions are stable. Most people should stick with Gimp 2.10.10 for this reason, unless they are the adventurous type and don't mind errors and/or crashes.
PostPosted: Fri Apr 12, 2019 11:26 pm  (#5)
:ninja
Using the link I posted, you may talk directly to Sylvie et Michel.
PostPosted: Fri Apr 12, 2019 11:58 pm  (#6)
Thanks for the info.
I will download it in a few Min.....
Doron
PostPosted: Sat Apr 13, 2019 9:25 am  (#7)
I think you are incorrect on this statement. The odd-even stability applies to the second number i.e. 2.8.xx is stable, 2.9.xx is developmental, 2.10.xx is stable.
PostPosted: Sat Apr 13, 2019 10:11 pm  (#8)
:ninja
Thank you dinasset. :bigthup
PostPosted: Sun Apr 14, 2019 2:01 am  (#9)
:tyspin , Thank you so much Dinasset. I'll install it just when I come back from my family holidays.
PostPosted: Sun Apr 14, 2019 11:31 am  (#10)
:ninja
Rod, I forgot to tell you that to talk with Sylvia you have to click on the "commentaires" then enter your comment/request of info, look:
PostPosted: Mon Apr 15, 2019 4:31 pm  (#11)
I just love these portable editions, too bad I cannot compile them myself.
ps
Does this work in windows xp?
PostPosted: Tue Apr 16, 2019 1:40 am  (#12)
Mr Ed wrote:
.....ps Does this work in windows xp?
At a rough guess, the translation of: Malheureusement la version 32 bits ne fonctionne pas sous Windows 32 bits ! is no.
PostPosted: Wed Apr 17, 2019 2:00 am  (#13)
Unfortunately - it has to be clearly stated:
For users of 32bit systems - Gimp has ended on version 2.10.6. :geek
I compiled Gimp 2.10.11 on my old computer (32 bit Window Vista) and unfortunately the same problem
https://www.gimp-forum.net/Thread-Please-help-edit-32-bit-Windows-installation?pid=12354#pid12354
PostPosted: Tue Apr 30, 2019 7:21 pm  (#14)
Too bad!
