It is currently Sat Nov 07, 2026 9:56 am
 Post subject: samj 2.10.13 Portable 32 bits et 64 bits pour Windows
PostPosted: Tue Aug 20, 2019 4:43 am  (#1)
:wvy
samj 2.10.13 Portable 32 bits et 64 bits pour Windows:
https://samjcreations.blogspot.com/2019/
 Post subject: Re: samj 2.10.13 Portable 32 bits et 64 bits pour Windows
PostPosted: Tue Aug 20, 2019 5:30 pm  (#2)
Thanks for the update!
PostPosted: Fri Aug 23, 2019 12:46 am  (#3)
Best wishes for Samj.
This is the first time Samj version doesn't work for me.
What's the cause ?
Gegl.
With CrashLog (GIMP-crash.txt):
Error occurred on Friday, August 23, 2019 at 07:24:50.
gimp-2.10.exe caused an Illegal Instruction at location 00000000700020E1 in module libgegl-0.4-0.dll.
AddrPC           Params
00000000700020E1 0000000000000000 0000000064945126 0000000000000000  libgegl-0.4-0.dll!gegl_render_op
0000000057224AE3 0000000000000000 00007FF8A2B89770 0000000000000001  libgobject-2.0-0.dll!g_type_class_ref
000000005720C6E6 0000000000FDE800 0000000070002904 0000000000000007  libgobject-2.0-0.dll!g_object_new_with_properties
000000005720CED2 0000000000000007 00000000572B2C11 0000000000000000  libgobject-2.0-0.dll!g_object_new
0000000070004057 0000000000FDCD98 000000000000002B 0000000000FDEDA0  libgegl-0.4-0.dll!gegl_config
00000000004015A1 000000000000002B 0000000000F59030 0000000001660840  gimp-2.10.exe!0x15a1
000000000090171A 0000000000000000 0000000000F59AC0 0000000000CC5108  gimp-2.10.exe!0x50171a
000000000040138C 0000000000000000 0000000000000000 0000000000000000  gimp-2.10.exe!0x138c
000000000040148B 0000000000000000 0000000000000000 0000000000000000  gimp-2.10.exe!0x148b
00007FF8A2B84034 0000000000000000 0000000000000000 0000000000000000  KERNEL32.DLL!BaseThreadInitThunk
00007FF8A2CF3691 0000000000000000 0000000000000000 0000000000000000  ntdll.dll!RtlUserThreadStart
gimp-2.10.exe   2.10.13.0
Someone can confirm the problem?
PostPosted: Fri Aug 23, 2019 1:46 pm  (#4)
It is working fine for me, althought I have only done limited testing. GMIC is also working.
PostPosted: Sat Aug 24, 2019 2:01 am  (#5)
:wvy No problem for the moment
PostPosted: Sat Aug 24, 2019 9:44 am  (#6)
Thank you very much for the tests.
I tried again on another computer (Windows 10 Home 64bit with the latest update) - same error (gimp does not start):
"gimp-2.10.exe caused an Illegal Instruction in module libgegl-0.4-0.dll".
I am confused because the version Gimp-2.10.12_Portable-32-64bit-Win-V2 works without a problem.
I will have to wait for the next version - because "stupid" substitution of libgegl-0.4-0.dll (from 2.10.12 to 2.10.13) creates more errors.
PostPosted: Sat Aug 24, 2019 12:26 pm  (#7)
It'sweird , MareroQ ..
I specify that I have Windows 10 home, 64 bits, and last version:
PostPosted: Sun Aug 25, 2019 1:22 am  (#8)
The problem (for some computers) has been solved.
A new version Gimp-2.10.13_Portable-32-64bit-Win-V2 is available (plugin WMF 0.2.8.4 is already installed).
Do you believe that the number thirteen is unlucky?
The problem for my computers is still identical (and the probable reason lies in their "non-factory" structure).
Many thanks to Sylvie et Michel.
PostPosted: Sun Aug 25, 2019 2:22 am  (#9)
Thanks MareroQ for this info. :)
And many thanks also to Sylvie and Michel.
