I am still using Gimp 2.10.14 95% of the time, I do have a portable (sort of ) Gimp 2.8 that comes out occasionally and I do like to try out the development appimage as well. The new compact toolbox is a great improvement.
For those of us who are inveterate dabblers
If usage was the other way around, using the appimage all the time, then I am not happy with unpacking 9000 files (500 MB) into /tmp folder every time I run it.
I might consider this. These appimages can be unpacked into a local folder, basically a permanent installation run from that folder. Might save a bit of wear and tear on your computer SSD drive but these are quite robust these days. Up to you. I might unpack that appimage on my storage partition like this, in a folder gimp-app (can be any name)
/media/rich/Data/gimp-app$ ./GIMP_AppImage-git-2.10.19-20200305-withplugins-x86_64.AppImage --appimage-extract
Gimp is then run from the folder squashfs-root/
./AppRun There are still writes to /tmp but only 500 small symbolic links (90 kB)
The appimage still uses the Gimp appimage profile for your personal resources (can be changed but do not advise mixing an older Gimp with Gimp 2.10.16/18/20...)
There it is in action with an old Gimp 2.8 script:
Any snags with that version?
Same as any Gimp 2.10 The nuFraw plugin interferes with loading a SVG (unsupported file format) Disable
plug-ins/NUFraw/plug-ins/nufraw-gimp until required.
Liquid-Rescale, totally broken. So far I do not know a fix. G'mic has a seam-carving filter that can be used.
Not at all sure that the bump-map plugin is completely backward compatible. Keep an old plugin handy
