It is currently Sat Nov 07, 2026 9:56 am
 Post subject: Samj has released 2.10.16 portable for windows
PostPosted: Wed Feb 19, 2020 6:56 pm  (#1)
Samj has released 2.10.16 portable for windows.It can be downloaded from her website:
https://samjcreations.blogspot.it
 Post subject: Re: Samj has released 2.10.16 portable for windows
PostPosted: Wed Feb 19, 2020 8:22 pm  (#2)
I just checked GIMP.org and there's no word that 2.16 was even available yet. :)
PostPosted: Thu Feb 20, 2020 8:33 am  (#3)
Installed.
After many uses without errors, I got the first one in the function "browse patterns", activated by clicking on a pattern parameter in a filter.
If someone else has installed it, and if (s)he has a filter with a "browse" patterns parameter (not mine, preferably), could (s)he double-check?
Here what I get:
Thanks
PostPosted: Thu Feb 20, 2020 8:47 am  (#4)
P.S. same kind of error when selecting a gradient or a palette from a filter parameter
PostPosted: Thu Feb 20, 2020 9:11 am  (#5)
Different system, but similar error when trying to select gradient. All plugins seem to be effected.
attempted to install procedure "temp-procedure-number-1" with invalid parameter name "gradient width".
Apparently the "width" part is invalid.
PostPosted: Thu Feb 20, 2020 10:06 am  (#6)
I can also confirm a bug in Gimp 2.10.16 from gimp.org.
Another fatal version - two steps back :gaah
PostPosted: Thu Feb 20, 2020 10:50 am  (#7)
Sylvie et Michel wrote: the error is reported
"https://gitlab.gnome.org/GNOME/gimp/issues/4641"
PostPosted: Thu Feb 20, 2020 4:39 pm  (#8)
Hi lylejk! If you have Windows, you can download it from here: https://download.gimp.org/mirror/pub/gi ... 0/windows/
Scroll down and you can find it on the bottom of the page.
PostPosted: Thu Feb 20, 2020 4:41 pm  (#9)
This is the GIMP 2.10.16 download: https://download.gimp.org/mirror/pub/gi ... 0/windows/
Scroll down and find it at the bottom of the page.
PostPosted: Fri Feb 21, 2020 12:58 am  (#10)
Indeed it's there but still not on GIMP.org's main site. Wonder why they've not updated the website yet? May install it after my weekend shift (next Tuesday); going to see if others experience issues or not. lolol
PostPosted: Fri Feb 21, 2020 4:05 am  (#11)
@lylejk I'd suggest staying well away from 2.10.16: https://gitlab.gnome.org/GNOME/gimp/issues/4643
PostPosted: Fri Feb 21, 2020 11:26 pm  (#12)
There is no problems with this case with Windows. I tried it and it's working fine.
PostPosted: Fri Feb 21, 2020 11:33 pm  (#13)
...as long as you do not have to select a pattern, or a gradient, or a palette...used by a filter
PostPosted: Sat Feb 22, 2020 8:50 am  (#14)
Thanks for the head's up, Kevin. Hopefully they'll figure the problem and fix it before releasing 2.10.18. :)
PostPosted: Sat Feb 22, 2020 8:56 am  (#15)
which might be quite soon ;)
https://github.com/GNOME/gimp/commit/3a ... 1d59e4936a
PostPosted: Sun Feb 23, 2020 1:42 am  (#16)
Recent news:
https://mail.gnome.org/archives/gimp-de ... 00011.html
However, in my opinion if they release without a patch for
then developers will make a very big mistake.
PostPosted: Sun Feb 23, 2020 3:55 pm  (#17)
I think you are right MareroQ. I was wondering why the newest AppImage is 2.10.17 and not 2.10.16. I guess they are just going to jump over that one. It's not a big issue for me, because I rarely change the default settings on plugins. I'm sure other people will have issues with it however.
I guess people will have to go through the trouble of editing their favorite scripts again. :roll:
The underlying real problem was a change in GLIB that stopped accepting property-names including ' ' spaces.
Every plug-in installing procedures whose property-name includes a ' ' has to be changed.
By the way, how does one go about editing scripts to correct this?
PostPosted: Sun Feb 23, 2020 5:23 pm  (#18)
However, it appeared today:
gimp-2.10.18-setup.exe 23-Feb-2020 20:28 204M
This is very, very sad but there are still errors for plugins and scripts. :yell :wh
