It is currently Sat Nov 07, 2026 9:56 am
 Post subject: GIMP 2.10.18 released
PostPosted: Mon Feb 24, 2020 5:52 pm  (#1)
gimp.org still released the new version 2.10.18 despite of all the errors that are causing on 3rd party scripts. Whyyyyy :gaah
 Post subject: Re: GIMP 2.10.18 released
PostPosted: Mon Feb 24, 2020 6:34 pm  (#2)
Hi Pocholo.
Unfortunately it's the truth.
However, I suppose Samj will soon release version 2.10.18 with this bug's temporary fix.
PostPosted: Mon Feb 24, 2020 7:49 pm  (#3)
Thank you for the Info. MareroQ :yes
PostPosted: Mon Feb 24, 2020 10:34 pm  (#4)
I am not clairvoyant but version Samj Créations
GIMP 2.10.18 Portable 32 bits et 64 bits Win
with bug fix for plugins and scripts (compared to Gimp 2.10.18 from gimp.org)
is now available:
https://samjcreations.blogspot.com/2020 ... -bits.html
PostPosted: Mon Feb 24, 2020 11:50 pm  (#5)
Yes, installed Samj's portable pack and the selection of palettes, patterns, gradient work fine !
PostPosted: Tue Feb 25, 2020 1:00 am  (#6)
I'm sticking with 2.10.14 until this idiocy gets addressed. Thanks for the heads up/warnings. :)
