It is currently Sat Nov 07, 2026 9:56 am
 Post subject: New Gimp 2.10.19 appimage 2020402 (Linux)
PostPosted: Fri Apr 03, 2020 7:01 am  (#1)
This version seems to run faster to me. It also works correctly with every plugin I tried including the old "LUCE" plugin, which hasn't worked for a while.
https://github.com/aferrero2707/gimp-appimage/releases
http://reddog.s35.xrea.com/wiki/Luce%20for%20GIMP.html
 Post subject: Re: New Gimp 2.10.19 appimage 2020402 (Linux)
PostPosted: Fri Apr 03, 2020 12:15 pm  (#2)
Sounds promising. Thanks for the heads up.
PostPosted: Fri Apr 03, 2020 1:17 pm  (#3)
Thanks for the information.
I run Linux inside my ChromeBook.
I will run the software as soon as possible.
Doron
4X5DF
PostPosted: Sat Apr 04, 2020 7:07 am  (#4)
Does anyone know - does this version work with Ubuntu 18.04 LTS?
I am asking because I want to install this version (dual boot Ubuntu with Windows 10).
PostPosted: Sat Apr 04, 2020 7:28 am  (#5)
It works fine even though it is not created in 'buntu. It is 64 bit only. It creates a separate user profile ~/.config/GIMP-AppImage/ so you can keep your existing Gimp settings.
Snags? Not many.
I go for the with-plugins version since it contains most of the lib files needed to run many compiled plugins. Nufraw plugin does stop SVG files loading. Does it work with Rawtherapee / Darktable ? Not sure, but I do not think so.
edit:
..and if you are willing to tinker.. This CMYK / RGB import / export with the cyan plugin https://i.imgur.com/dG6i03d.jpg
Wireless printer scanner using XSANE and gutenprint https://i.imgur.com/BMwxTll.jpg
....but I still keep a regular Gimp 2.10.14 - just in case ;)
PostPosted: Sat Apr 04, 2020 7:49 am  (#6)
Hi Rich2005.
Thank You so much for your comprehensive reply.
PostPosted: Sat Apr 04, 2020 9:38 am  (#7)
Yes, SVG files open fine if you use Darktable to import RAW files. I don't have Rawtherapee installed, so can't comment on that. The problem seems limited to Nufraw.
