It is currently Sat Nov 07, 2026 9:56 am
 Post subject: New Gimp VER 2.10.20
PostPosted: Wed Jun 10, 2020 4:05 am  (#1)
Hi Gimp users
There is a new version of gimp.
Ver 2.10.20 from 09.JUN.2020
Link to the new VER
Doron.
 Post subject: Re: New Gimp VER 2.10.20
PostPosted: Wed Jun 10, 2020 4:25 am  (#2)
Here's hoping....
PostPosted: Wed Jun 10, 2020 10:58 am  (#3)
Focus blur is new. Vignette? I don't recall seeing it before.
PostPosted: Wed Jun 10, 2020 12:04 pm  (#4)
GNU Image Manipulation Program
2.10 Stable Branch
This is the stable branch of GIMP. Unlike earlier stable branches,
we do allow some new features here, if they are not too invasive.
Otherwise, this branch is only for bug-fixes.
Overview of Changes from GIMP 2.10.18 to GIMP 2.10.20
Tools:
- Crop tool now has a "Delete cropped pixels" option active only in
image crop mode, allowing to choose whether to crop layers or only
the canvas (cropped pixels will be made invisible as out-of-canvas
but would still be present). The option is unchecked by default,
as it is the non-destructive behavior, which also means the
default behavior is changed.
- Crop tool in image crop mode will not crop layers with "Lock
pixels" on, anymore, even if "Delete cropped pixels" is checked.
- Painting tools can now restore opacity and blend mode from
presets.
User interface:
- Image / Precision renamed to Image > Encoding
- Tool groups can now display their tool list on hover rather than
on click. This can be set in Preferences, in the Toolbox tab.
- Improved update notification GUI in About dialog, and now also
showing an update comment when one was set in gimp_versions.json.
- Palette Editor dockable: the color index in the current palette is
now shown in front of the color name.
Plugins:
- In file-psd, make the data_start and data_len fields of the
PSDimageres and PSDlayerres structs unsigned, to avoid potential
overflow/sign-extension
- file-raw: Canon CR3 files are now properly recognized by GIMP and
sent to your raw developer software of choice.
- PNG and TIFF export: "Save color values from transparent pixels"
defaults now to not saving color values (i.e. channels set to 0)
when alpha channel is present and 0 itself.
- PDF import: multi-pages are now imported in bottom-first order,
similar to animated formats, and also similar to defaults for PDF
export. This brings consistency but break existing behavior, hence
needs to be noted.
- Added support for exporting 16-bit PSDs, read and write channels
from/to PSd in the right order
Filters:
- The 'Vignette' filter now has on-canvas controls
- New 'Filters -> Blur -> Focus Blur' filter with on-canvas controls
to emulate out-of-focus blurring
- New 'Filters -> Blur -> Variable Blur' filter that uses an aux
mask input to blur an image with variable intensity
- New 'Filters -> Light and Shadow -> Bloom' filter
Updated translations:
- British English, Catalan, Chinese (Taiwan), Dutch, Finnish,
German, Greek, Italian, Korean, Polish, Romanian, Russian,
Spanish, Swedish, Turkish, Ukrainian
Icons:
- Replace fileicon.ico with version contain 24x24, 64x64, 128x128,
and 256x256 sizes for Windows icon
- Replace wilber.ico with version containing 128x128 size of Windows
icon
Bug fixes:
- #189, #354, #872, #1439, #3405, #3533, #3558, #3777, #3841, #4094,
#4328, #4363, #4487, #4618, #4641, #4663, #4696, #4734, #4745,
##4793, 4827, #4846, #4858, #4871, #4895, #4904, #4919, #4967,
##4968, #4992, 4996, #5009, #5010, #5033
Developers:
- Ell, Jehan, lillolollo, Marco Ciampa, Michael Natterer, Øyvind
Kolås, pesder, Salamandar, Sergio Jiménez Herena, Simon Budig, T
Collins, woob
Contributors:
- Nikc, Sabri Ünal, Michael Schumacher, Jernej Simončič, luz.paz
Translators:
- Alexandre Prokoudine, Anders Jonsson, Bruce Cowan, Cristian
Secară, Daniel Korostil, Daniel Șerbănescu, Dimitris Spingos, Jiri
Grönroos, Jordi Mas, Nathan Follens, Piotr Drąg, Rodrigo Lledó
Milanca, Sabri Ünal, Seong-ho Cho, Tim Sabsch, Yuri Chornoivan,
Георгий Тимофеевский
