It is currently Sun Nov 08, 2026 7:39 am
Post new topic Reply to topic  [ 49 posts ]  Go to page 1, 2, 3  Next
 Post subject: New Gimp Ver 2.10.24
PostPosted: Wed Mar 31, 2021 2:37 pm  (#1)
Hi Gimp Users
A new Gimp Ver 2.10.24
New Gimp Info Page
Doron
 Post subject: Re: New Gimp Ver 2.10.24
PostPosted: Wed Mar 31, 2021 4:40 pm  (#2)
There has been problems with this release.
Version 2.10.24-setup-2 has been released.
Still problems.
gmic crashing in this release.
PostPosted: Wed Mar 31, 2021 7:20 pm  (#3)
Downloading Gimp 2.10.24 setup 2 now.
Edit: Right out of the gate on start up, I get bombarded with at least 20 or so errors involving plugins, scripts, etc.
The first error I received when trying to load gimp was:
Finally when it started to load, I get this:
Everything I had on GIMP 2.10.22, is completely gone. When I do update, all of my plugins, the theme selector, and scripts don't disappear when installing a new updated version. With GIMP 2.10.24, everything disappeared. I'm using Windows 10 64 Bit.
PostPosted: Wed Mar 31, 2021 8:49 pm  (#4)
If you put all GIMP 3rd party in your C:\Users\YourName or Users\AppData\Roaming\GIMP\2.10 you should have it all there. Do not to place any of the 3rd party stuff in you Hard drive. If you did once you update you will lose it all.
PostPosted: Wed Mar 31, 2021 8:58 pm  (#5)
I have all of my GIMP plugins here:
The first error that came up is the problem and then the others after that.
PostPosted: Wed Mar 31, 2021 9:39 pm  (#6)
I'll pass. lol
PostPosted: Wed Mar 31, 2021 9:44 pm  (#7)
I'll pass. lol
I should have done the same. I didn't. Now i'm stuck with a non working version of gimp. This was setup 2. Version 1 was blocked when I tried downloading it.
PostPosted: Wed Mar 31, 2021 10:50 pm  (#8)
As usual, I will wait for the package released by Sylvie et Michel (SAMJ).
Since 2.10.18 I abandoned the official release in favour of Samj's self-contained pack (hence without any interference with previous releases).
PostPosted: Wed Mar 31, 2021 10:58 pm  (#9)
I could post the errors I have, but I don't want to bore all of you with screenshots I have.
PostPosted: Thu Apr 01, 2021 4:09 am  (#10)
I have 2.10.24 on my Linux Mint 20.1 (ubuntuhandbook repo), didn't experience anything unusual.
PostPosted: Thu Apr 01, 2021 4:18 am  (#11)
I'm on Windows 64 Bit. Each system is different. I didn't experience these errors with the previous version of Gimp.
PostPosted: Thu Apr 01, 2021 4:48 am  (#12)
Didn't know ubuntuhandbook was so up to date. I usually run the AppImage, but that hasn't updated yet. I may try ubuntuhandbook just to check it out of curiousity.
PostPosted: Thu Apr 01, 2021 7:19 am  (#13)
gmic not loading has been reported as bug 6670 @ gitlab.
PostPosted: Thu Apr 01, 2021 9:50 am  (#14)
mackenzieh, If you are on Windows, go to Restore and pick a date before you started to add the new version. It should go back to the previous version (if you are lucky).
PostPosted: Thu Apr 01, 2021 2:39 pm  (#15)
I've tried that before with an other program and a restore won't work.
PostPosted: Thu Apr 01, 2021 2:51 pm  (#16)
I went back and downloaded setup one for the new gimp version. This time around, gmic throws errors on startup.
I raised the question on social media for gimp. I received an answer and according to Michael Schumacher, on twitter, the GMIC error is something for the creator of GMIC to address.
PostPosted: Thu Apr 01, 2021 5:23 pm  (#17)
Thanks Nidhogg about the tip on ubuntuhandbook repo. I installed it and so far everything is working great. No problem with G'mic either. Actually G'mic runs better in the PPA vs the AppImage. I'm also running Linux Mint 20.1 for those interested.
PostPosted: Thu Apr 01, 2021 6:17 pm  (#18)
From David @ gmic.
"Yes, we confirm the problem. I'm on it to try and get it to work properly, as quickly as possible."
PostPosted: Fri Apr 02, 2021 4:35 am  (#19)
New gmic version released.
Thank you David @ gmic
PostPosted: Fri Apr 02, 2021 4:51 am  (#20)
So what was the problem with the old version of G'mic? Because I have yet to experience any problems using G'mic 2.9.4 in Gimp 2.10.24 and I tried a whole bunch of different filters. Could the G'mic problem be limited to Windows?
