It is currently Sat Nov 07, 2026 9:29 am
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2, 3  Next
 Post subject: 2.10.28 released/gmic resolved
PostPosted: Thu Sep 16, 2021 5:59 pm  (#1)
Just downloaded 2.10.28.
Gmic crashed when opened.
 Post subject: Re: 2.10.28 released
PostPosted: Thu Sep 16, 2021 8:20 pm  (#2)
Gimp.org still lists 2.10.24 as the current and stable download.
PostPosted: Thu Sep 16, 2021 8:31 pm  (#3)
The site has yet to be updated. 2.10.28 is an official stable release from the direct download link.
PostPosted: Thu Sep 16, 2021 8:42 pm  (#4)
Here's a screenshot of the download page on gimp.org:
I am using Windows.
PostPosted: Thu Sep 16, 2021 8:49 pm  (#5)
I am aware of this. Please read my post #3 again.
PostPosted: Thu Sep 16, 2021 9:03 pm  (#6)
I've read post #3. The title of your post says that 2.10.28 released. You then posted that you downloaded it and G'MIC crashed. Where did you download it from? It's not on the official site. The direct download link is 2.10.24.. not 2.10.28. Also, version 2.99.6 is the development version.
PostPosted: Thu Sep 16, 2021 9:09 pm  (#7)
This is the GIMP server link...
https://download.gimp.org/pub/gimp/v2.10/windows/gimp-2.10.28-setup.exe
PostPosted: Thu Sep 16, 2021 9:10 pm  (#8)
00111111 wrote:
Thanks. :) That's what your initial post was missing. I think you should edit post #1 and put the link there. I will give the download a shot.
PostPosted: Thu Sep 16, 2021 10:14 pm  (#9)
G'MIC Errors in GIMP 2.10.28 on Windows:
PostPosted: Fri Sep 17, 2021 2:10 am  (#10)
GIMP 2.10.26 works fine with G'MIC 2.9.9 :bigthup
BTW you should report this to GIMP...
https://gitlab.gnome.org/GNOME/gimp/-/issues
Patrice
PostPosted: Fri Sep 17, 2021 2:44 am  (#11)
I can get that error as well. Very clean installation, Gimp 2.10.28 / gimp_gmic_qt v. 2.9.9 ( also tried 3.0 - it is the same)
This has happened before: The gimp_gmic_qt QT libraries need updating. Someone should inform David Tschumperle
PostPosted: Fri Sep 17, 2021 3:04 am  (#12)
I did.
And GMIC.
PostPosted: Fri Sep 17, 2021 3:08 am  (#13)
@mackenzieh @rich2005
Thank you for confirming.
PostPosted: Fri Sep 17, 2021 4:59 pm  (#14)
It's 2.10.28 that has the problem. Not 2.10.26
PostPosted: Fri Sep 17, 2021 6:38 pm  (#15)
From gitlab:
Sylvie Alexandre @samj · 10 hours ago
Bonjour,
This is a problem of updating the DLLs.
It's reported.
While waiting for the update on http://gmic.eu/ you can try this version :
GMIC 2.9.9 + GMIC-QT + GMIC-GIMP-QT for Gimp-2.10 - Win 64bit
Download...
Install : readme.txt in the archive
WFM. Thank you samj
PostPosted: Fri Sep 17, 2021 7:21 pm  (#16)
00111111 wrote:
From gitlab:
Bonjour,
It's reported.
Download...
WFM. Thank you samj
Where does the styles folder go that has the qwindowsvistastyle.dll file?
PostPosted: Fri Sep 17, 2021 7:35 pm  (#17)
I only replaced the "qmic gimp qt" folder in plug-ins.
PostPosted: Fri Sep 17, 2021 8:45 pm  (#18)
PostPosted: Fri Sep 17, 2021 9:03 pm  (#19)
Not required.
If you place "qmic gimp qt" folder in plug-ins can you run gmic?
PostPosted: Fri Sep 17, 2021 9:15 pm  (#20)
00111111 wrote:
Not required.
Yes, I can still run gmic. I was just curious to where the styles folder would go if I were to use the theme.
