It is currently Sat Nov 07, 2026 9:29 am
 Post subject: I Made A Gmic-Gimp Appimage
PostPosted: Wed Mar 30, 2022 3:17 am  (#1)
This idea worked. Because Gimp is a dependency of 'gimp-gmic' it's possible to make a Gimp appimage (quite easily) that fully integrates gmic.
This appimage is G'MIC 2.9.6 and Gimp 2.10.24.
The method uses deb packs from the same repo. I notice G'MIC 3.02 is out so I could pair that with Gimp 2.10.30 or later.
I wasted a lot of time trying to bundle Python2.7 into this. I wish it was integrated into GIMP. Afferero used a lot of scripting to bundle his Gimp appimages but they are hard to recycle for me :) I got it down to 215Mb and learned how to do thinning.
AppImages usually load from /tmp/ with a random ID. Afferero got around this by making them use the same ID.
 Post subject: Re: I Made A Gmic-Gimp Appimage
PostPosted: Sun Apr 03, 2022 1:38 pm  (#2)
The Aferrero's appimage continuous release allowed us to use the latest G'MIC (the one that we download from https://gmic.eu ), even the one with plugin https://github.com/aferrero2707/gimp-ap ... continuous
May be you don't need to include G'MIC? If so your appimage will be lighter as well :mrgreen:
Patrice
PostPosted: Mon Apr 04, 2022 4:43 am  (#3)
Hi Patrice,
I have been using the new LTS Ubuntu 22.04 for a few weeks and it's getting close to release. I've noticed some changes. Firefox is now only installed as a snap (which has its own root folder.)
I think G'MIC is now installed with Gimp. That's a good move. It's there and I didn't install it.
I like playing with appimages now that I can make them from debs. Ubuntu DVD installers use squashfs so I can't see them dropping appimage support. It is a security risk but so is dropping coffee in your machine :) Squashfs lets you move symlinks to other computers which normal file systems can't do.
I got the old MathMap plugin for Gimp working in a Gimp 2.10.30 appimage. I notice it's animated sphere filter has x,y and z axis which makes it a 3d app. Maybe G'MIC has some 3d filters. David is a smart guy.
PostPosted: Mon Apr 04, 2022 5:23 am  (#4)
Just a reminder about 'buntu 22.04 and presumably spin-offs
Appimage (rockridge system) mounts using fuse. In particular fuse2 which is deprecated in 22.04 where fuse3 is default. You can still install fuse2.
This goes back a year, upto 3 weeks ago, worth a read
https://github.com/AppImage/AppImageKit/issues/1120
I use quite a few appimages, LibreOffice, Krita etc.. However when it comes to Gimp the PPA's now have Gimp 2.10.30 versions that run in 'buntu 18.04 / 20.04 so an appimage, as an update, not really necessary anymore.
PostPosted: Wed Apr 06, 2022 10:53 pm  (#5)
Hi Rich, there are no issues with AppImages and fuse3 on the latest Ubuntu 22.04 jammy. They all work.
I notice Firefox loading as a snap file takes longer than it used to.
PostPosted: Thu Apr 07, 2022 3:37 am  (#6)
Tas_mania wrote:
Hi Patrice,
What??? Ohh gosh Noooo! It's time for me to switch distro as I just HATE snaps, they made me very snappy.
It's 2 years that my kids are on MX Linux (they are my distros test :hehe ), it's a pure joy.
(although Ubuntu-MATE is rock solid, 6 years in a row without any problem and as fast as the first day, but forcing me snaps... No)
GIMP installed with G'MIC, good, but I'm sure it's a snap :mrgreen:
That's cool that mathmap works with your appimage, I'll give a try to your appimage (is it with mathmap inside?)
Indeed G'MIC has 3D filters/things like 3D animations, mostly in "Rendering" and "Sequences", and even 3D effect/maps in "Stereoscopic 3D")
Patrice
PostPosted: Thu Apr 07, 2022 5:06 am  (#7)
Hi Patrice, Gimp and GMIC could be part of a clean install from DVD. I upgraded 2 of my systems and now I'm not sure :(
Snaps - losing 5 to 10 seconds everytime you start a browser adds-up over the life of a system. Because it's linux somebody will come-up with an alternative.
I uploaded a Mathmap Lite AppImage
I called it 'Lite' because it loads an installed Gimp version 2.10.30. The appimage starts Gimp with MathMap (and GMIC if its installed).
I'm thinning a 'Full' Gimp/MathMap/GMIC at the moment and the target is Ubuntu 20.04 and 22.04.
PostPosted: Thu Apr 07, 2022 6:13 am  (#8)
Looks that way, I did an upgrade to 22.04 (VirtualBox) and the warning message has gone. The only one I really tried is the latest Inkscape 1.1.2 appimage and that starts up ok.
Very clever, I disabled my regular mathmap installation, Kubuntu 20.04 / Gimp 2.10.30 (from PPA) and that works....but oh the bloat ;) 90 MB for a plugin+files that occupies 3.5 MB
PostPosted: Thu Apr 07, 2022 6:19 am  (#9)
Very clever,
I wish. I thought the bloat was gimp but it was actually loading the installed gimp hence I called it 'Lite'. I didn't even look inside it - lots more thinning :)
PostPosted: Thu Apr 07, 2022 6:07 pm  (#10)
I ran the Mathmap lite appimage, but can't locate mathmap. Where exactly should it be found so I can test?
PostPosted: Thu Apr 07, 2022 6:24 pm  (#11)
Hi racer-x, its in Filters > Generic > MathMap > MathMap
I cut-down the AppImage to 2.7Mb.
This AppImage was a mistake but turned out to be a novel way of launching a Gimp plug-in. Tha MathMap binary calls Gimp and doesn't care where it is :)
Composer is tricky to use but can make 2d animations.
The video is terrible because I was having coughing fits while making it. Not sure what happened I don't do dope.
PostPosted: Thu Apr 07, 2022 6:36 pm  (#12)
This latest one doesn't work here on Linux Mint 20.3 (ubunto 20-04). The other light version works but mathmap doesn't show up. After extraction, it seems the mathmap link is broken.
PostPosted: Thu Apr 07, 2022 9:54 pm  (#13)
None of them work, the 2 version (80Mb and the 2.7Mb) does nothing (yes I give it the right to be executed as program)
Ubuntu-MATE 20.04, GIMP 2.10.30 PPA from Panda Jim, your appimage launched from my ~/Desktop/
Patrice
PostPosted: Fri Apr 08, 2022 4:14 am  (#14)
I made a MathMap AppImage for Ubuntu 20.04 systems.
When tested it loaded the installed Gimp 2.10.18 for this Ubuntu.
I'm interested in how it goes (or doesn't go) on a 20.04 system.
PostPosted: Fri Apr 08, 2022 4:38 am  (#15)
Tas, that last one "Gimp-Math-MapUbuntu-20-04-x86_64.AppImage" launches here just fine, but again no mathmap. I presume mathmap must be installed in system for it to work as it lists the mathmap link as broken. I checked when I extracted the appimage and looked in "squashfs-root/root/usr/lib/gimp/2.0/plug-ins/".
PostPosted: Fri Apr 08, 2022 5:13 am  (#16)
Hi racer, its in squashfs-Lite/root/usr/bin/mathmap.
In Gimp it's under Filters > generic
Making appimages this way is based on deb packs so its close to the original operating system. I haven't tested on the PPA downloaded Gimps so have no idea.
If you are interested you could start it in a terminal in the same folder:
./GimpMathMapUbuntu20-04-x86_64.AppImage --verbose > start.txt
This usually shows a missing lib or something else.
PostPosted: Fri Apr 08, 2022 5:33 pm  (#17)
I get this...
/usr/lib/gimp/2.0/plug-ins/mathmap: error while loading shared libraries: libgtksourceview-2.0.so.0: cannot open shared object file: No such file or directory
gimp: LibGimpBase-WARNING: gimp: gimp_wire_read(): error
Tried to install "sudo apt install libgtksourceview-2.0.so.0". That's a no-go...
PostPosted: Fri Apr 08, 2022 6:09 pm  (#18)
Hi racer-x
I added the files can you download it again from here?
I installed the ubuntuhandbook Gimp 2.10.30 which I think you use and all works here.
PostPosted: Fri Apr 08, 2022 7:11 pm  (#19)
OK now it complains: "/usr/lib/gimp/2.0/plug-ins/mathmap: error while loading shared libraries: libgslcblas.so.0: cannot open shared object file: No such file or directory"
PostPosted: Fri Apr 08, 2022 8:32 pm  (#20)
Hi racer I updated the appimage again hopefully for the last time. The other GC users must think I'm hogging the site :)
https://github.com/TasMania17/Gimp-Appi ... untu-20-04
