It is currently Sat Nov 07, 2026 8:52 am
 Post subject: Gimp new Ver 2.10.32
PostPosted: Mon Jun 13, 2022 10:21 pm  (#1)
Hi gimp users
There is a new Ver of gimp
Link to the new Ver.
Doron
4X5DF
 Post subject: Re: Gimp new Ver 2.10.32
PostPosted: Tue Jun 14, 2022 1:47 am  (#2)
From the NEWS:
Overview of Changes from GIMP 2.10.30 to GIMP 2.10.32
Core:
- Adding support for localized glyphs ('locl') in Text tool depending
on the value of the "Language" field in Text tool options.
- XCF import nows drop Xmp.photoshop.DocumentAncestors tags after 1000
of them, similarly to what libgimpbase now does. This could happen
in XCF files which were created e.g. from a PSD import before we
handled the issue in libgimpbase.
- XCF import:
* made more robust by ignoring (with a warning) invalid
parasites and continuing to load the rest of the file (which might
be valid). This way, we are able to salvage more cases of
partially corrupted XCF files.
* additional safety checks to detect broken XCF files.
- Version check can be globally disabled through a value in the
`gimp-release` file. This would allow to use the same build on
repositories with an update channels (where we don't want update
check notifications) and on standalone (where we want them).
User Interface:
- Removed titlebar/borders from Windows Splash Screen.
- All official themes now have on-hover indicator around eye and link
toggles in Layer/Channel/Path Dialog tree-views.
- Dark theme:
* Hover-on effect on radio menu items to improve readability.
- Color icon theme:
* Thin contrast border for 'close' and 'detach' to improve their
readability against dark backgrounds on mouse-hover.
Plug-ins:
- TGA: improving indexed images with alpha channel support (both
import and export).
- DICOM: Fix endian conversion for photometric interpretation
"MONOCHROME1".
- file-raw: "RGB Save Type" confusing dialog label renamed to "Palette
Type" as on the main dev branch.
- screenshot: option to capture cursor in now available on Windows.
- pygimp: new optional parameter `run_mode_param` (defaulting to True)
to register() function of the Python binding, which allows to make
the "run-mode" parameter optional when creating a new PDB procedure.
This is already used to fix "file-openraster-load-thumb" without
changing its signature.
- BMP: new PDB procedure "file-bmp-save2" which supports all options
available interactively.
- BigTIFF: our TIFF plug-in now officially supports BigTIFF import and
export.
* Import was actually already working transparently if you had
a recent enough libtiff. Now the recent libtiff is enforced by
dependency requirements.
* Export support was added with a checkbox in the interactive dialog
and a new "bigtiff" argument in the "file-tiff-save" PDB
procedure.
* When an interactive export of ClassicTIFF fails for the explicit
reason of "Maximum TIFF file size exceeded", the export dialog is
raised again with a message proposing to try again as BigTIFF or
trying another compression algorithm.
This allows because discoverability and understandibility of the
issue, while not forcing BigTIFF export (since it might not be
supported everywhere).
* Unlike the same change on the main dev branch, this backport comes
without a dependency requirement bump, which means this will only
work if GIMP is built with recent enough libtiff.
- Raw: more robust load able to load as much as possible from the
file, then fill the rest with white, when offset and dimensions are
bigger than actual file size.
- Improved support of a few plug-in code for building under UCRT
Windows environment (more modern C runtime library than MINGW).
- EPS: loading transparent EPS files now supported.
- JPEG XL: import backported from the `master` (2.99) branch.
- WebP: export has a new IPTC checkbox (saved through XMP) as well as
a thumbnail checkbox. (backported from dev branch, since 2.99.8)
- DDS: export has a new flip option (useful for some game engine) as
well as a new savetype option to export all visible layers (not only
the active one).
- TIFF:
* import support for 8 and 16 bit CMYK(A) TIFF files.
* 1, 2 and 4-bit B/W images are now converted to indexed rather than
grayscale as it seems that there is more of a use case for these
images to be handled as indexed, even though technically they can
be considered grayscale.
In the future we could add an option at loading time where the
user can choose whether they prefer it to be loaded as indexed or
grayscale.
* Fix loading images generated by MATLAB's blockproc function.
* More robust loading for 8 bps grayscale MINISWHITE TIFF.
Libgimp:
- New gimp_plug_in_error_quark() as a generic GQuark/GError domain for
plug-ins (backported from 2.99.6).
- gimp_drawable_brightness_contrast() now works in the [-1.0, 1.0]
range (it's more of a fix than a change because it's what it should
have been from the start).
- Better management of modification time in metadata: IPTC tag
Iptc.Application2.DateCreated is not overridden anymore as it is the
original creation date of the image. Instead we set the XMP tag
Xmp.xmp.ModifyDate for file modification time and
Xmp.xmp.MetadataDate for metadata modification time.
- Format of Xmp.tiff.DateTime is now properly set with timezone as a
consequence of the previous improvement.
Libgimpbase:
- Limit to 1000 ancestors when importing images with incredible amount
of `Xmp.photoshop.DocumentAncestors` tags, which is most likely due
to a bug in some versions of Photoshop (in some PSDs, we encountered
over 100,000 such tags; it probably makes no sense that a document
could have that many ancestor documents). GIMP will now stops at
1000 such tags before dropping the rest and continue loading the
file.
Icons:
- Chain icons for the Color icon theme reworked from the Symbolic
versions (with contrast borders to work on any background color) so
that the "broken" and full variants are easily distinguishable.
Translations:
- New Galician and Georgian translations for the Windows installer.
- 20 translations were updated: Catalan, Chinese (China), Croatian,
Danish, Dutch, Finnish, French, Georgian, German, Hungarian,
Icelandic, Italian, Polish, Portuguese, Russian, Slovenian, Spanish,
Swedish, Turkish, Ukrainian.
Build:
- Bumping minimum GEGL to version 0.4.36.
- The Windows installer now has an option /DISABLECHECKUPDATE=true to
install the same build but editing the `gimp-release` file to
disable update check as newly implemented (see above in Core
section).
PostPosted: Wed Jun 15, 2022 11:22 pm  (#3)
Thank you. Installed and working. :)
PostPosted: Sat Jun 18, 2022 10:44 pm  (#4)
I know some users have been waiting for this release.
This time it's a Samj Personal Build (thanks a lot for that :tyspin ) and a bit different from the official gimp.org build.
I can see a few differences: in speed, window widgets ...
PostPosted: Mon Aug 22, 2022 9:09 pm  (#5)
I use Linux but does this GIMP version use python3 and includes the python fu menu?
PostPosted: Tue Aug 23, 2022 1:32 am  (#6)
It still uses python2 .
It's included in the flatpak version.
Regards
nelo
PostPosted: Tue Aug 23, 2022 2:25 am  (#7)
No it does not use python 3, but python2, but it's not a problem with the Tas_mania appimage https://github.com/TasMania17/Gimp-Appi ... -for-Linux
Patrice
PostPosted: Tue Aug 23, 2022 3:24 am  (#8)
@cecilia
You can still use the old gimp-python packages with Ubuntu 20.04 - That is what I use with my (k)ubuntu 20.04 / Gimp 2.10.32 installation..but it is a pain to install and when you do eventually update to Ubuntu 22.04 those old packages no longer work anyway.
For either 'buntu 20.04 or 22.04 the Tas_mania appimages work very well.
This is already a bit out of date, the appimages have been refined down to two versions but at least it is a demo of what to look out for. https://youtu.be/9xGMhK6hPVQ
