It is currently Sun Nov 08, 2026 5:45 am
 Post subject: Gimp-2.99.13 nightly build for Windows 64
PostPosted: Fri Oct 28, 2022 8:13 am  (#1)
Updated branch 24 hrs ago. Loaded great in Windows 64 bit. A portable unstable version for testing only purposes. Of course.
Screenshot.
If you have previously installed a Gimp-2.99.12 version this portable will use existing theme and window profiles for that install. You can get it here if you are interested in testing.
https://gitlab.gnome.org/GNOME/gimp/-/branches
Start from the Windows cmd file. (included)
 Post subject: Re: Gimp-2.99.13 nightly build for Windows 64
PostPosted: Fri Oct 28, 2022 8:47 am  (#2)
Which one is the 2.99.13 nightly build for Windows 64?
Michael
PostPosted: Fri Oct 28, 2022 11:33 am  (#3)
I do not know where Rod's portable version is.
The Gimp devs do make it easy for you, but my take on it.
If you go here: https://gitlab.gnome.org/GNOME/gimp/-/p ... _schedules. Click on the last pipeline entry for windows installer.
That gets you to here and click on the win-installer-nightly to download a zip file.
The contents of the zip file contains an installer.
Tried in a Win7 VM, 64 bit and it works. I still think it has one of the ugliest UI's of any Gimp.
oops, max three attachments so onto imgur
PostPosted: Fri Oct 28, 2022 12:14 pm  (#4)
Many thanks for the effort!
(And hopefully there will be a mid grey theme soon too...)
PostPosted: Fri Oct 28, 2022 12:29 pm  (#5)
oh, it is in there, in the usual place Edit -> Preferences and a system theme option + color icons to replace the symbolic ones.
PostPosted: Fri Oct 28, 2022 1:36 pm  (#6)
Really?! Great. Can't wait to see it. In 2.99.12 there's only "Compact", "Default" and "System"... None of them i'ld use..
PostPosted: Fri Oct 28, 2022 1:54 pm  (#7)
YES! It works and the "Gray" theme is pleasant. I like it.
PostPosted: Sat Oct 29, 2022 3:04 am  (#8)
MichaJo wrote:
The attachment gitlablink29913.jpg is no longer available
Michael
It states that the pipeline failed but it worked fine for me.
Be sure and unzip it to a folder in C drive. Portables folder or some such name. Create it yourself.
Then open the gimp-w64 folder and run the command file.
PostPosted: Sat Oct 29, 2022 7:58 am  (#9)
I'm trying to see if I can get the GEGL Operations from 2.99 to work on 2.10. So far I got the useful gradient map and the horrible not so useful inpaint filter. But many others will not build.
