It is currently Sun Nov 08, 2026 7:39 am
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
 Post subject: GimpScripts is shutting down
PostPosted: Sat Apr 13, 2024 4:44 am  (#1)
I am going to miss it.
Charles
 Post subject: Re: GimpScripts is shutting down
PostPosted: Sat Apr 13, 2024 4:55 am  (#2)
Same here.
I wonder why this has to be.
PostPosted: Sat Apr 13, 2024 6:26 am  (#3)
Huh, why?
PostPosted: Sat Apr 13, 2024 8:23 am  (#4)
Most script fu stuff and all python 2 stuff is not currently working in 2.99.19
PostPosted: Sat Apr 13, 2024 2:07 pm  (#5)
And the new GEGL functions will pretty much obsolete the old scripting option. Would be nice if gimp scripts would zip all the scripts and send them to the internet archive for those who want them.
PostPosted: Sat Apr 13, 2024 2:45 pm  (#6)
Which is why a lot of people will stick to Gimp 2.10 for a while...
PostPosted: Sat Apr 13, 2024 10:17 pm  (#7)
Indeed, and sure I will
Patrice
PostPosted: Sun Apr 14, 2024 8:15 pm  (#8)
Once GMIC works on Gimp 2.99.19/RC1 it will be irrational for me to use Gimp 2.10
GMIC is the only holdout for me
PostPosted: Sun Apr 14, 2024 9:12 pm  (#9)
You're lucky :bigthup , I suppose that you don't really use paths (for example)
Patrice
PostPosted: Sun Apr 14, 2024 9:52 pm  (#10)
yes, I currently have a monopoly on Gimp plugins. GMIC, Script Fu and Python stuff are not working but my plugins are just fine.
I didn't intend this.
PostPosted: Mon Apr 15, 2024 3:47 am  (#11)
Can GEGL plugin like yours create new layers?
PostPosted: Wed Apr 17, 2024 12:53 am  (#12)
I must admit that Mahvin's decision also surprised me a bit.
However, the statistics do not look very interesting - the monthly number of views does not exceed 20,000 (i.e. on average about 300 per day).
However, Mahvin declares that it is possible to transfer gimpscripts.net to a person interested in taking it over (with the waiver of the website name and leaving it open until it is transferred to its own hosting).
You can also create a page mirror for yourself .
I consider it pointless to place just plug-ins "somewhere" without describing their purpose.
PostPosted: Sat Apr 20, 2024 7:29 am  (#13)
PostPosted: Sat Apr 20, 2024 11:50 am  (#14)
Not in Gimp but GEGL has a something called composers that function as virtual layers and blend modes
gegl:src = replace blend mode
gegl:over = normal blend mode
gegl:dst-over = behind blend mode
gegl:src-atop = normal blend mode alpha locked
gegl:src-in = replace blend mode alpha locked
The others are self obvious blend modes like
gegl:overlay
gegl:multiply
gimp:layer-mode layer-mode=grain-merge
gimp:layer-mode layer-mode=vivid-light
In Gimp everything is applied in one layer, but GEGL has an internal "layer like" system.
PostPosted: Sat Apr 20, 2024 12:35 pm  (#15)
ok, thanks for clarifying.
PostPosted: Sat Apr 20, 2024 6:32 pm  (#16)
I have a lot of plugins there :bawl Somebody with experience can create a Blog in (Blogger) can take it and I believe it's free. I'm just saying!
PostPosted: Sat Apr 20, 2024 6:43 pm  (#17)
I'm sorry to hear about this.
PostPosted: Sun Apr 21, 2024 3:16 am  (#18)
To all the folk who have worked so hard over on GimpScripts.
Best of luck in all your future endeavours.
PostPosted: Sun Apr 21, 2024 5:01 am  (#19)
You can wget the website https://www.gimpscripts.net/ but that did not download the script files
For the files I had to wget https://mahvin.bplaced.net/gimpscripts/
Anyone with a good command line for the whole lot in one go ?
PostPosted: Sun Apr 21, 2024 12:27 pm  (#20)
Downloading everything in one go with this
wget -e robots=off --reject="index.html*" --no-parent --recursive --relative --level=1 --no-directories https://mahvin.bplaced.net/gimpscripts/
EDIT: Total Downloaded: 583 files, 470M
Patrice
