It is currently Mon Nov 09, 2026 12:30 am
 Post subject: GIMP 3 now has GEGL automation in python console
PostPosted: Wed Dec 18, 2024 9:26 pm  (#1)
The latest commits made by GIMP's lead dev Jehan made it possible to add GEGL filters non-destructively in GIMP 3 using python console.
This is a new interested feat for plugins and automation, many good things will come out of it. I expect the community to go far with it but there is one disappointment, It isn't capable of using multiple GEGL filters in composers (without writing GEGL syntax) like GEGL syntax is. So don't expect this strategy to replace my plugins that rely on that tactic. So remember, its not an alternative to my plugins but it is a new way to incorporate GEGL.
 Post subject: Re: GIMP 3 now has GEGL automation in python console
PostPosted: Thu Dec 19, 2024 9:37 am  (#2)
Non-destructive GEGL filters open up a lot of possibilities.
it’s a valuable tool.
Your plugins and GEGL clearly serve a unique purpose and fill a gap.
It’s great to see how this is evolving.
PostPosted: Fri Dec 20, 2024 2:36 pm  (#3)
Entering this command applies gaussian blur as a filter from python console
This only works in current master builds of GIMP 3 RC1 + Git from yesterday (dec 19 2024) onward.
img = Gimp.get_images()[0]; l = img.get_layers()[0]
f = Gimp.DrawableFilter.new(l, "gegl:gaussian-blur", "")
c = f.get_config()
c.set_property("std-dev-x", 12.0)
c.set_property("std-dev-y", 12.0)
c.set_property("clip-extent", 0)
f.update()
l.append_filter(f)
PostPosted: Fri Dec 20, 2024 5:43 pm  (#4)
I made the first GEGL based python script using my plugins. It requires many of my plugins to work but the point is the layer effects are applied as GIMP filters as opposed to a GEGL graph.
f = Gimp.DrawableFilter.new(l, "lb:clay", "")
c = f.get_config()
c.set_property("elevation", 52.0)
f.update()
l.append_filter(f)
f = Gimp.DrawableFilter.new(l, "lb:glowstick", "")
c = f.get_config()
f.update()
l.append_filter(f)
f = Gimp.DrawableFilter.new(l, "gegl:levels", "")
c = f.get_config()
c.set_property("in-high", 0.6)
f.update()
l.append_filter(f)
f = Gimp.DrawableFilter.new(l, "gegl:hue-chroma", "")
c = f.get_config()
c.set_property("hue", 180.0)
c.set_property("chroma", 20.0)
f.update()
l.append_filter(f)
f = Gimp.DrawableFilter.new(l, "lb:glassovertext", "")
c = f.get_config()
f.set_blend_mode(Gimp.LayerMode.NORMAL);
f.update()
l.append_filter(f)
f = Gimp.DrawableFilter.new(l, "gegl:saturation", "")
c = f.get_config()
c.set_property("scale", 2.1)
f.update()
l.append_filter(f)
c = f.get_config()
c.set_property("std-dev-x", 10.0)
c.set_property("std-dev-y", 10.0)
f.set_blend_mode(Gimp.LayerMode.BEHIND);
f.update()
l.append_filter(f)
c = f.get_config()
c.set_property("scale", 1.0)
f.update()
l.append_filter(f)
PostPosted: Fri Dec 20, 2024 6:10 pm  (#5)
This is great news! Thanks for pointing this out and for all your hard work. Cheers. :coolthup
Charles
PostPosted: Fri Dec 20, 2024 7:26 pm  (#6)
Personally, I'd rather just apply layer effects on a layer group and send the .xcf of the layer group to people so they can just type text inside a layer group to get a text style.
but I can see how this alternative would be really cool because it can make new layers and interact with GIMP directly.
PostPosted: Fri Dec 20, 2024 8:24 pm  (#7)
This is a great 1st GEGL Python cosole filter to create new ones. Thanks for sharing Contrast.
PostPosted: Sat Dec 21, 2024 3:36 am  (#8)
Yeah, I expect Python to offer a lot of possibilities when combined with Gegl.
I'm still in the dark about DrawableFilter. I'm going to wait for RC 2 to check out the documentation. Do you know if we will have access to an existing Gegl layer group filter via the DrawableFilter?
Charles
PostPosted: Sat Dec 21, 2024 7:45 am  (#9)
gasMask: It should be possible, since a LayerGroup is a type of Layer (that's why implementing filters on layer groups was fairly simple when we first did it).
PostPosted: Sat Dec 21, 2024 12:10 pm  (#10)
That's interesting and good to know. I was using contrast_ terminology, where he has created a complex filter with a group of effects and alters a single layer. I'm wondering if the DrawableFilter has been set up to access his filters that are built into Gimp 3.
Charles
PostPosted: Sat Dec 21, 2024 2:34 pm  (#11)
gasMask: GimpDrawableFilter should be able to use any GEGL operation that you have installed on your version of GIMP - both the built-in ones and any plug-ins you have. You can add multiple filters to a layer as well, to create combined effects.
PostPosted: Sat Dec 21, 2024 4:28 pm  (#12)
How do I make a new layer in python 3 console?
PostPosted: Sat Dec 21, 2024 7:17 pm  (#13)
Contrast do you have to have an existing text layer for the python-GEGL console effect to work?
Never mind. Stupid question. :lol
PostPosted: Sat Dec 21, 2024 9:07 pm  (#14)
Copy and paste this function:
def add_layer(image, parent=None, position=0, layer_name="Base"):
    layer = Gimp.Layer.new(
        image,
        layer_name,
        image.get_width(),
        image.get_height(),
        Gimp.ImageType.RGBA_IMAGE,
        100,
    image.insert_layer(layer, parent, position)
    return layer
Get a list of open images:
images = Gimp.get_images()
Get the first open image:
image = images[0]
Create a layer:
layer = add_layer(image)
Charles
PostPosted: Sat Dec 21, 2024 9:35 pm  (#15)
        image,
        layer_name,
        image.get_width(),
        image.get_height(),
        100,
    return layer
image = images[0]
Create a layer:
Its not working in GIMP 3
PostPosted: Sun Dec 22, 2024 2:36 am  (#16)
Did the console spit out an error? It could be a problem caused by a newer Gimp version.
File comment: It works here. I created an image first.
Charles
PostPosted: Sun Dec 22, 2024 4:24 am  (#17)
Writing Python plugins in Gimp-3.0 was supposed to be very easy. :hehe :flirt :tantrum
However, the real improvement would be adding GEGL filters to PDB :bowdown
PostPosted: Sun Dec 22, 2024 4:27 am  (#18)
The DrawableFilter could be easier than PDB, IDK, but it really depends on the documentation of a Gegl DrawableFilter.
I think that Python 3.11 is easier to program than Python 2.7 especially with VSCode. When the documentation of Gimp, GimpUi, Babl, etc. modules is done, it should be easier.
Charles
PostPosted: Mon Dec 23, 2024 12:44 pm  (#19)
Paste this in the latest build of GIMP 3's python console. Its an awesome text style that doesn't require my plugins
f = Gimp.DrawableFilter.new(l, "gegl:color-overlay", "")
c = f.get_config()
g = Gegl.Color.new("#ff0800")
c.set_property("value", g)
f.set_blend_mode(Gimp.LayerMode.REPLACE);
f.update()
l.append_filter(f)
f = Gimp.DrawableFilter.new(l, "gegl:bevel", "")
c = f.get_config()
c.set_property("type", "bump")
c.set_property("radius", 6)
c.set_property("blendmode", "lighten")
f.update()
l.append_filter(f)
f = Gimp.DrawableFilter.new(l, "gegl:inner-glow", "")
c = f.get_config()
g = Gegl.Color.new("#006cff")
f.set_blend_mode(Gimp.LayerMode.OVERLAY);
f.update()
l.append_filter(f)
f = Gimp.DrawableFilter.new(l, "gegl:dropshadow", "")
c = f.get_config()
g = Gegl.Color.new("#ffffff")
c.set_property("color", g)
c.set_property("x", 0.0)
c.set_property("y", 0.0)
c.set_property("grow-radius", 7)
c.set_property("radius", 1.0)
c.set_property("opacity", 1.0)
f.update()
l.append_filter(f)
c = f.get_config()
g = Gegl.Color.new("#000000")
f.update()
l.append_filter(f)
c = f.get_config()
c.set_property("x", 4.0)
c.set_property("y", 4.0)
c.set_property("grow-radius", 3)
c.set_property("radius", 9.0)
c.set_property("opacity", 0.9)
f.update()
l.append_filter(f)
PostPosted: Thu Jun 12, 2025 6:20 am  (#20)
@contrast_ @gasMask Thanks a lot for sharing your examples, there are not a lot of it yet and it helps to start :bigthup
I am currently using Visual Studio Code to write my Python scripts for Gimp. It works quite well, but what I do not get to work is to get the typings of "Gimp". I import the namespace with `from gi.repository import Gimp`, but there is no autocomplete.
With `from gi.repository import GLib, Gio` this works for GLib and Gio, probably because I added the typings with `pip install PyGObject-stubs`.
Is there any dependency I can install to get the Gimp bindings/types?
