It is currently Sat Nov 07, 2026 8:00 am
 Post subject: No longer is there a Tool Options icon
PostPosted: Sat Mar 21, 2026 1:54 am  (#1)
This has been removed and tool that is in use is used instead. :yes
 Post subject: Re: No longer is there a Tool Options icon
PostPosted: Sat Mar 21, 2026 2:06 pm  (#2)
Thanks for pointing this out sallyanne.
I didn't notice this change.
It seems to have been absorbed into the active tool workflow,
which is great.
:jumpclap :clap :jumpclap
This streamlines things nicely making the workflow much smoother.
PostPosted: Sun Mar 22, 2026 2:53 am  (#3)
I must be blind ... I still don't see what's missing.
PostPosted: Sun Mar 22, 2026 6:54 am  (#4)
In version 3.2.0
Here I have chosen the move tool. Last tool options icon was the same for each tool. If you hover over the icon showed above your tool options you will also see it says tool options
@wallace, may make it easier for people new at gimp too
