It is currently Sun Nov 08, 2026 7:05 am
 Post subject: Gimp 2.7.3 new build & G'MIC 1.5.0.0
PostPosted: Sun Aug 07, 2011 9:42 pm  (#1)
Hi All,
I know it's been awhile. :)
However, summer is always like that. However, I have not been idle. I just uploaded new builds based on the source as of August 6, 2011. So, feel free to update your Gimp version.
Also, now that G'MIC stable version is 1.5.0.0. So, I updated that as well. Please keep in mind that the author updates G'MIC frequently and so it is not possible to post beta's since I just don't have the time. I will try to keep up, but no promises. The author also provides the 32 bit version, so all is not lost. :)
As usual, please let me know if you have any issues.
Thanks,
Partha
www.partha.com.
 Post subject: Re: Gimp 2.7.3 new build & G'MIC 1.5.0.0
PostPosted: Sun Aug 07, 2011 9:57 pm  (#2)
Thanks for the G'MIC update Partha; now I have my new presets show up too. :)
PostPosted: Mon Aug 08, 2011 2:00 pm  (#3)
For XP 32 bit
- using the Eyedropper - Gimp crashes;
- error when opening file *. ps and *. eps (although the preview is correct. GS_PROG is not a reason because it works well in the 2 .6.11).
PostPosted: Tue Aug 09, 2011 1:06 pm  (#4)
May be the problem, because the path for gimp- 2.6.11 is different from a path to gimp-2.7.3
more if you use gimp 64 bit version, also the library used (in this case Ghostscript )may require to be compiled for 64 bit.
i had a similar problem with the previous build from partha,but i really gave no much attention because to the problem since both are sort of vectorial files and gimp can't edit vectors
So i only noticed that was no working but i thought the problem was GS at 32bit but gimp at 64
PostPosted: Tue Aug 09, 2011 1:30 pm  (#5)
Partha nice idea include last stable Gmic
Gmic will advice in a clear way if a new version is available, in case just after calling gmic will appear a red and bold advice about newer release available.
PostPosted: Tue Aug 09, 2011 8:02 pm  (#6)
Hi PC,
Long time no talk! I have not forgotten your last email so will go back to it as the summer progresses.
Thanks for the validation re: G'MIC. I am glad you are OK with it. Keeping up with the betas would be a pain. :)
Partha
PostPosted: Tue Aug 09, 2011 8:08 pm  (#7)
MareroQ wrote:
For XP 32 bit
I will have to investigate the XP 32 bit eye-dropper issue. I don't have an XP machine handy at the moment. It does not crash on my Windows 7 machine.
I don't know what to say about PS and EPS files. It is very strange that when I start Gimp in my Msys environment, I can open PS files. Matter of fact the current screenshot on my website is a PS file (escher.ps which is part of the examples in the GS installation). However, when I install in the Windows environment, I loose this ability. So, will have to look into the source code to figure out what is going on unless someone has some ideas.
Thanks,
Partha.
PS: Thanks to Willy for getting me to investigate themes and so, some of the common theme engines are already included in the build. So, most themes should work. See the write-up on the website.
PostPosted: Wed Aug 10, 2011 10:06 am  (#8)
Partha - many thanks for your work !
I am very happy with this version and slowly forget about the 2.6.11 - this probably is 90% of Gimp 2.8 !!!
More about eyedropper:
It is interesting that this (small) error only (?) in XP 32 bit SP3 (Home and Professional).
It's just the little things - the point is that:
- [1] is working properly;
- use [2] or [3] - works poorly and freezes access to menu File and Edit (but only at the maximum window ...when you reduced windows "restore down" - the access is again possible...);
- in the window - "Change Foreground Color" - does not work "Add the current color to the color history" [4].
PostPosted: Wed Aug 10, 2011 6:06 pm  (#9)
You are welcome! :)
Thanks for the screenshot and now I know what to look for.
Partha
